20-04-2019 #21One of their downsides is that I think brushed DC servos are used - so they will have a finite life, I will swallow that
Do those motors have integral brakes? If not, you might need to add one on the Z axis if you're going to run a big fat (end hence heavy ) spindle - servos don't have the stiffness that steppers have when the power's off, and depending on gearing etc., you might get a slowly drooping spindle when you switch off.Last edited by Voicecoil; 20-04-2019 at 09:57 AM.
The Following User Says Thank You to Voicecoil For This Useful Post:
20-04-2019 #22
An excellent point which I had not considered! Unfortunately no brake.
I plan to use the following 3.5kW spindle and VFD:
https://www.aliexpress.com/store/pro...1bdf23a8f7ed5m
https://www.aliexpress.com/store/pro...2e6c275cpko9w1
At 8kg, this spindle may well cause problems.
I will most likely use a fairly high gear reduction on the Z (maybe 5:1 or even higher as compared to 2:1 on X/Y). Perhaps this will amplify any holding force/friction enough to keep it in place when powered off. If it does turn out to be a problem I guess I could always buy an external brake like this (though I won't have a convenient 24v supply for it, nor will I know how to connect it, maybe using a relay on the BOB or something...)
https://www.zappautomation.co.uk/24v...brake-2nm.html
I'm also not particularly happy about the C10/C11 breakout board that comes with the kit. The wiring diagram is a bit scant and I am not sure it has all the features I need for spindle control - and I don't know what a charge pump is, or if I need one, but it doesn't seem to have one.
If I am feeling up to it I may use the kit as an inspiration to piece together my own system using some more custom parts - but I'm already overwhelmed by the complexity of all this!
That's what she said
20-04-2019 #23
FY! a charge pump is an electronic circuit that's usually used to generate a low-ish power but higher DC voltage from the existing DC supply using capacitors, rather than an inverter/transformer/boost converter arrangement - e.g. generating 10V from a +5V supply.
That's what she saidLast edited by Voicecoil; 24-04-2019 at 08:50 AM.
23-04-2019 #24
I've created a build log where I can press ahead with my ideas: would welcome any more comments you guys may have!
tooling for hardwood
By BobE in forum Woodwork DiscussionReplies: 2Last Post: 02-12-2018, 10:27 AM -
FOR SALE: Conect 121 CNC Lathe (s)! Ex High School.
By DMY in forum Items For SaleReplies: 8Last Post: 01-11-2018, 11:45 PM -
WANTED: SCHOOL DT Dept needs basic Denford or Roland router running 2D Design
By scoutcentre in forum Items WantedReplies: 1Last Post: 31-01-2018, 09:53 PM -
FOR SALE: Various Items of equipment for sale from a Barnsley Secondary School
By DLODGE in forum Items For SaleReplies: 4Last Post: 07-08-2012, 06:53 AM -
Hardwood Supliers?
By Stickio in forum Marketplace DiscussionReplies: 3Last Post: 06-01-2011, 11:21 AM
