16-04-2019 #1
I’ve spent a lot of time lurking on this great forum and planing my next machine. I’ve finally accepted the extent of my ignorance and am now totally in a state of decision paralysis - please help!!
I am an electric guitar luthier and for a few years I have used a small and crappy chinese 3018 CNC for inlay work and fretboard carving. Its been a trial but I have learnt a lot. I’m pretty skilled with using both handheld and tablemounted routers and working with wood in general. I also have a software and electronics background, reasonable mechanical savvy but little no metalworking experience.
I’ve decided to take the plunge into using CNC to carve full guitar bodies and necks. I will need a working area of at least 900 x 400 mm to achieve this - whilst bigger would certainly be more flexible (e.g. for occasional bass guitars necks and neck-throughs) I think keeping it smaller is better - for size and weight constraints. In the rare case I need to, I’m happy to tile the work.
Here are some of my initial thoughts which I’d really appreciate a sanity check on:
1) My feeling is that for reasonably large hardwood pieces I need to ensure a high feedrate is possible - at least 5000mm/min if not 10000. Accuracy is important but I think not as critical as for you metalworking guys - my feeling from my handbuilt guitars is that 0.1mm accuracy is totally sufficient. Is my thinking on the right track?
2) Rigidity obviously a key concern as it would be for any machine - I’d like to take as high a DOC as possible. I’ve seen lots of youtube videos of chaps CNCing guitars, and often I’m very surprised by the very small bits they seem to use (often around 1/4”). This seems really strange to me - I’d rarely use such a smal bit in a handheld router. The obvious thing is, I need a spindle capable of taking ER20 collets, but the more difficult problem is finding a machine/design that provides adequate rigidity to do justice to something like a 1” ball nose with a 3mm DOC.
3) Machine weight is a major headache. Its quite possible my workshop may need to relocate and I am concerned about having a 200kg behemoth to drag through doors and around stairs. I appreciate this is going to limit the rigidity I can expect! My best hope I think is having a machine that is straightforward to dismantle (ruling out the relatively attractive full table sized chinese offerings).
4) Cost is certainly a consideration but to some extent it is not the limiting factor - the weight problem dominates.
Here are my options as I see them:
1) Build my own. I have taken great interest in the build described here http://www.mycncuk.com/threads/11266-3-Axis-900x500mm. Similar requirements to my own and a largely modular aluminium design. Machined aluminium sideplates would be the biggest challenge for me but I can potentially access a CNC machine at my local hackspace. I’d look to use 4Nm Nema23 motors and add a pulley coupling mechanism - hopefully allowing me to tune the gearing for a good balance of accuracy/speed (also it seems much more difficult to get hold of 1610/2010 ballscrews compared to 1605 so I see gearing as a way around that). I could perhaps dedicate a full month of my time to this build and have costed it to around £3k - is this mad?
2) Omio 9060 CNC for around £3k all in (https://www.omiocnc.com/x8-2200epl.html). Looks like a generic chinese machine but with all the trimings (2.2kw water cooled spingle, square supported rail, ballscrews, bellows, reasonably quick shipping). Would this be much worse than option 1? In some ways the basic design is very similar to the design for 1, aluminium extrusions with aluminium endplates. Motors are directly coupled though and a max speed of 4000mm/min which seems a little slow. A respectable performance in the following video even using a tiny router cutter for some reason (https://www.youtube.com/watch?v=HyMO89obfmg)
3) A brace of comparatively heavy and rigid machines which utilise at least some steel frame components. These tend to be more expensive and not to use square supported rail and some even use ACME lead screws - on paper this sounds like bad news but I wonder whether the overall machine rigidity is more important than the “sum of the parts”?
a) JBEC 106512
£7k+ and a lukewarm mycncuk reception (http://www.mycncuk.com/threads/6389-...able-in-the-UK)
but I have seen some videos of quite impressive guitar building performance (https://www.youtube.com/watch?v=OCC_4lJcRAI)
b) Kompas H - 1000 GS KIT
Eastern european wildcard, £1.5k for a mechanical only soltuion - could do the electronics myself but max speed seems really low
c) CRP4828
Mechanical only for £2.5k - could do the electronics myself. Seems like old technology, using roller bearings and ACME leadscrews. Still has admirable performance as in this example (https://www.youtube.com/watch?v=1VEebB157G4). Maybe the rigid frame and modular construction make it a winner?
d) I tech K6090T (https://www.scosarg.com/itech-k6090t-q-series-desktop-cnc-router)
£5.5k and seems to have all the right qualities - square rails, ballscrews, fast traverse! This seems to be the pick of the bunch but at 200kg I worry about transportability. How would you move this around if it was yours? Theres an unboxing video of this machine on youtube and they use a chain hoist to get it up on the workbench!
Wow, that was quite a lot. If you got this far I’m really grateful. Any help or advice you can give would mean the world to me at this stage!Last edited by bluesking; 16-04-2019 at 07:33 PM.
The Following User Says Thank You to bluesking For This Useful Post:
17-04-2019 #2
Hi bluesking
I also machine guitars on my CNC machine (check my signature for my channel). I normally machine around the 3000mm/min mark using 4 to 10mm cutters dependant on operation and strategy (e.g. larger multi-flute cutters are great for adaptive/trochoidal clearing when roughing bodies and body pockets).
Personally I would go for option 1. as you will know what you are getting and can design out some of the compromises in the other options. £3K is not unreasonable for a decent aluminium framed machine (mine was about £2K-£2.5K including software).
Option 2 looks OK, but I'd like to see how that X axis (long axis) is being driven and the electronics might be a bit of a lottery (i.e. stepper type/voltage, driver type, controller board etc.).
Option 3 a. not familiar, but if there are valid criticisms from JAZZCNC or the other regulars here then I would heed them.
Option 3 b. not familiar so can't give an opinion
Option 3 c. I would not go for any machine with leadscrews and probably not without linear guides/bearing (square supported rails) given the choice these days.
Option 3d. You will likely find that many machines will start to get close or pass the 200Kg mark, once you get it fully loaded - generally provided the motors are sized correctly (and some other factors), heavier is better
Hope that helps.My CNC Projects: https://www.youtube.com/imadethisoncnc
The Following 2 Users Say Thank You to Washout For This Useful Post:
17-04-2019 #3
Washout, that really does help, thank you very much!
Option 1 certainly is attractive but I am somewhat concerned about disappearing down the rabbit hole into a long build. I'm prone to this anyway, and I can see myself getting carried away! At least if it turns out heavy I know I can easily dismantle it for transportation which solves that problem.
Option 2: X axis is driven by a single, central 2005 ball screw. As for electronics, they seem OK on paper. For my own build I was thinking about using this (https://www.cnc4you.co.uk/CNC-Kits/P...3-Axis-Nema-23). The Omio seems similar to what I would have used in my build, I think the drivers will be about the same, the PSU will run a little lower at 40V rather than 48V, and the steppers seem like they are 3Nm rather 4Nm (can't really tell, only info on the steppers is they are rated 4.2A - no idea what torque this corresponds to). Not really sure how different the BOBs would be. I don't know whether this all would really impact what I'm doing as my own design was based on what can easily be bought in at low risk (given they are packaged as a kit I was relying on compatibility), rather than on any real engineering design factors. Perhaps this kit would be overkill for what I need and perhaps the Omio would be just fine - or perhaps not?!?! Overall, at 95kg and with an easily removable gantry I would feel comfortable knowing I can also move it around.
The biggest differences I can see between the omio and my own design are:
a) Omio uses 5mm lead pitch with direct coupling between steppers and leadscrews - I was going to design belt-gearing to get a bit of extra speed. Either should be able to run at over 3000mm/min so perhaps this is irrelevant, given what speeds you have found work best. I'm hoping to use more standard router cutters than milling bits, 1/2" flat bits for clearing, 1" ballnose for contours and top carves - not really sure if these expectations are overambitious or just plain crazy - not seeing anyone else doing this - wonder why? Those are the bits I'd use when hand routing and I can't say the forces involved seem dramatic at all - some of my handbuilt guits have made use of these bits supported by pretty rudimentary MDF sleds and jigs - sure there is often around 0.5mm of flex - never caused any problems after sanding and finishing! Hell, I'm currently using an angle grinder for most of my top-carves - not fun, not accurate, but gets a great result in the end.
b) I would have used significantly larger extrusions - its hard to tell what size extrusions the omio utilises - but then the omio makes more use of more aluminium plate - have no idea what rigidity to expect from either option!
c) Omio will hopefully be much easier and quicker to get going on. Also, the bellows seem a nice touch, I have the feeling that the omio will be more protected from sawdust than anything I will ever end up designing.
I have just had a very reasonable price from Omio for supplying the X8 without the electronics or steppers. So a hybrid approach may be best (and even cheapest). With this I'd probably end up combining the omio mechanics with the cnc4you electronics kit and.... hoping.... that Robert really is your father's brother?!?!
I had a look at your youtube channel and realised I have already seen all of your Andy Summers tele build
during my research. I think I've seen every guitar CNC video on youtube by now haha. Really enjoyed your work, particularly nice and sharp sunburst you got on that one!
Cheers!
17-04-2019 #4
First welcome to the forum bluesking.
I would also go with option one as then you are in control. Have a look at Joe Harris build with a hand held router https://www.youtube.com/watch?v=pZo2...S3i705fuSogBXT
The motor kit is not good as the drives and power supply are not good enough. cnc4you is a good place to buy the motors (or Zapp. https://www.zappautomation.co.uk/ele...er-motors.html)
Wal's machine is currently being modified to make it into a twin screw type. I would advise you to do the same. This can be done with two screws and two motors nema 23 OR two screws and one motor nema 34 with one belt connection both screws and the motor. Both ways are fine personally I prefer two motors. The are pros and cons for both types.
I would go with about 68V power supply and em806 drives or am882 or even https://www.ebay.co.uk/itm/CNC-2DM86...oAAOSwKWJcnaQE.
Ball screws 1610 x and y 1605 on z tried and tested by many.
If you decide to build start a build log to keep all the question in one place. Good Luck..Clive
The Following 2 Users Say Thank You to Clive S For This Useful Post:
17-04-2019 #5
Thanks Clive,
Noted your advice about the drives and power supply - I had a nagging feeling this was a bad area to scrimp on but my choice was driven by ignorance rather than price. I'm sure if I went with your suggestions I'd be able to find someone here who has a wiring diagram for all these exotic options (exotic to me anyway!)
Also noted the need for substantial motoring to move the gantry.
Joe Harris build video is interesting. It looks like a sturdy machine, but what do I know?! It wouldn't work for me - as he rightly points out, making a steel frame structure which is easy to dismantle and reassemble without fubaring its alignment seems like a no go - I am currently moving workshop space and it seems quite likely I will have to move again within the foreseeable future - I can't afford a machine which I can't easily take with me!
I have already started design work in CAD for my build (2 variants actually). Once I have something ready to show I will definitely start a build log and seek comments.
To press on with my design I now really need to commit to either a moving gantry or a fixed gantry. I originally went with a fixed gantry based on what I saw this Maltese luthier doing (https://www.youtube.com/watch?v=6MCyIZIcg48). Its a bit rough and ready looking, but my mechanical intuition is telling me it is a good way forward. Certainly moving 2kg of wood seems like a much easier job than an entire gantry holding a 2.2kw ER20 spindle. Then I saw the thread of Wal's machine and I liked the simplicity and elegance of it - so I went down that route. Now I'm dithering again between the two (can you guess I'm a ditherer yet, hahaha?)
17-04-2019 #6Fixed gantry will take up more floor space and moving gantry. if you are comparing that with the one Wal built then there is no comparison between the two. I pointed you to Joe's machine not for the way it is built but the methods he used with the hand held router. Also he has on his site a very good vid on building the power supply. There are only three components in it.To press on with my design I now really need to commit to either a moving gantry or a fixed gantry. I originally went with a fixed gantry based on what I saw this Maltese luthier doing (https://www.youtube.com/watch?v=6MCyIZIcg48). Its a bit rough and ready looking, but my mechanical intuition is telling me it is a good way forward. Certainly moving 2kg of wood seems like a much easier job than an entire gantry holding a 2.2kw ER20 spindle. Then I saw the thread of Wal's machine and I liked the simplicity and elegance of it - so I went down that route. Now I'm dithering again between the two (can you guess I'm a ditherer yet, hahaha?)
I forgot but go for 20mm square rails if you can. all this can be got from Fred at BST in China along with the ball screws and bk bf bearings etc.
nemas 23 will be more than enough with the correct drives.Also noted the need for substantial motoring to move the gantry.
Re the CAD it is always a good idea to do a design first. I don't think Wal's machine is anything like 100KgLast edited by Clive S; 17-04-2019 at 04:51 PM.
18-04-2019 #7
Thanks again Clive,
Something has been sitting uneasy with me about all of this and I think I may have finally figured it out. When I'm seeing various machines cutting guitars on Youtube I'm generally left underwhelmed. I think it is most likely that I come from a purely woodworking background and metalwork is a foreign world to me. But what I actually need is a woodworking machine, I couldn't care less about aluminium (above and beyond any I need to machine to produce the CNC itself).
The only truly satisfactory results I've seen to date have been on HAAS-type machines. I've obviously been managing my expectations and ruled out anything in that league. And then suddenly I see this:
https://www.youtube.com/watch?v=LLNeA1oUCGc
This is the first time I've seen a desktop machine doing exactly what I hoped I could do. So I start trying to pick it apart - why is this machine doing what I require while I see no evidence that others are? Hard to see on the video, and the manufacturer K2CNC is now kaput. I follow some breadcrumbs and find some images of the machine:
https://www.hmres.com/site/images/pr...-8e6f-87f6.jpg
Looks OK, but pretty unremarkable. Yes its got square rails, yes, its probably using ball screws, yes it doesn't use steel, yes, its only using a single screw for the long axis, yes, it doesn't look all that sturdy. The only two remarkable things I notice are:
1 - Monster spindle - I don't know what power, but looks to be at least 3kW
2 - SERVOS!!!!
You can probably guess where my mind is going - and it does relate to my earlier whinging about everyone else using what I consider to be "small" cutters. I really want to use the cutters that I understand, and these are mostly big, multi-flute affairs. Now, my understanding is that I need to have substantial feed rates to generate good chips in such situations. My early research suggests steppers can certainly yield the same torque as servos, but also that servo's reach peak torque at high speeds, while steppers reach peak torque at low/zero speeds. Servos match my personal experience of hand-routing wood - a certain minimum feed rate is necessary to achieve controllable and clean cuts.
I get the impression that servos are a little rarer in most builds here and I understand they bring lots of extra cost and complexity. I'm particularly concerned that if I go down the servo route I may be out in no-man's land and perhaps less able to rely on the expertise of people here. Is there anyone here who can hold my hand a little and give me some advice about servos?
I may well be wrong, maybe steppers are perfectly sufficient, but I can now only convince myself of this if I can see them producing similar results to the above youtube link. At the end of the day, if I can't expect that sort of performance, I don't think I can justify investing so much time in a custom build!
18-04-2019 #8Yes bigger more powerful spindles like 3 kw you can use bigger cutters. If you want more motor power then use nema 34 but then you need higher voltage drives (mains voltage type).I may well be wrong, maybe steppers are perfectly sufficient, but I can now only convince myself of this if I can see them producing similar results to the above youtube link. At the end of the day, if I can't expect that sort of performance, I don't think I can justify investing so much time in a custom build!
The machine like Wal's in my opinion is far more sturdy than the one you linked to. Modern tool paths can out perform with greater speed and less spindle power. Why not have a look at some feed and speed calculators.
using 10mm pitch screws with steppers you can easily get 10mts/min You will be surprised how fast 5mts/min is on a small machine...Clive
18-04-2019 #9
Your requirements are not a million miles away from what I want to end up with, except mine will be used for building high-end loudspeakers rather than guitars (hence needs to be a bit larger); I've also had to think about the relocation issue. My advice if you're going to build your own is to go for a "raised side rail" arrangement, as then it's pretty easy to make the gantry detachable which would obviously help with moving the thing. But even so, I wouldn't be expecting the base part of anything that's properly rigid to be a one man lift - however if you're making one yourself you can of course build in handles/lifting points and provision for mounting it on a dolly or similar. I've also had a word with my pal Mike Vanden, one of the best archtop luthiers in the country, and he said don't get too hung up on feed rates as with some fancy hardwoods you can get a poor cut if you go too fast - he tends to work his Isel machine at 2000mm/min tops on standard wood and less if doing fine work on brittle stuff. A lot of the problem is that wood isn't a completely even material and some hardwoods are a bit on the brittle side; if you hit a hard spot/twisty bit near a corner on the end grain you can easily take a wee chip out of the edge. Using downward spiral cutters and machining the end grain first can help obviously, but won't solve everything all the time.
Regarding your comments on the K2CNC machine, it's difficult to say exactly what size that spindle is, but assuming the square rails are 20mm, I guess it could be a 2.2KW aircooled thing. Although servos have better torque at high rpm than steppers that doesn't mean you can't make a machine that goes fast enough for your kind of work using steppers, it's just a matter of getting the design right, there's a very useful motor/ballscrew calculator on this forum. And then there's now the closed-loop steppers available which are kind of a half-way house.
The Following 2 Users Say Thank You to Voicecoil For This Useful Post:
18-04-2019 #10
Thanks Clive, good food for thought.
Wal's machine certainly looks more sturdy than this K2. In fact, almost all machines I've seen look more sturdy than the K2. In my mind, this begs the question, why have I not seen any desktop machine performing as well as the K2 in this scenario?
It doesn't look like the timings will work out for me to see Wal's machine in action before pressing ahead with mine as I do need to get going. I'm sure you're right about 10/5 m/min, I couldn't even tell you what numbers the K2 is running at - all I can see is that the cuts look exactly what I want to be doing and I've not seen anything else that doest - leaves me with quite the risk of going down a dark path!
Compare the rickety K2 taking nice deep cuts with big cutters:
To these much more sturdy machines, seemingly taking their sweet time scratching away:
https://www.youtube.com/watch?v=F5Jy5cJscXU
https://www.youtube.com/watch?v=WatC-mihuoA
https://www.youtube.com/watch?v=Psr9Yt49grwLast edited by bluesking; 18-04-2019 at 11:09 AM.
tooling for hardwood
By BobE in forum Woodwork DiscussionReplies: 2Last Post: 02-12-2018, 10:27 AM -
FOR SALE: Conect 121 CNC Lathe (s)! Ex High School.
By DMY in forum Items For SaleReplies: 8Last Post: 01-11-2018, 11:45 PM -
WANTED: SCHOOL DT Dept needs basic Denford or Roland router running 2D Design
By scoutcentre in forum Items WantedReplies: 1Last Post: 31-01-2018, 09:53 PM -
FOR SALE: Various Items of equipment for sale from a Barnsley Secondary School
By DLODGE in forum Items For SaleReplies: 4Last Post: 07-08-2012, 06:53 AM -
Hardwood Supliers?
By Stickio in forum Marketplace DiscussionReplies: 3Last Post: 06-01-2011, 11:21 AM
