Thanks Clive, good food for thought.
Wal's machine certainly looks more sturdy than this K2. In fact, almost all machines I've seen look more sturdy than the K2. In my mind, this begs the question, why have I not seen any desktop machine performing as well as the K2 in this scenario?
It doesn't look like the timings will work out for me to see Wal's machine in action before pressing ahead with mine as I do need to get going. I'm sure you're right about 10/5 m/min, I couldn't even tell you what numbers the K2 is running at - all I can see is that the cuts look exactly what I want to be doing and I've not seen anything else that doest - leaves me with quite the risk of going down a dark path!
Compare the rickety K2 taking nice deep cuts with big cutters:
https://www.youtube.com/watch?v=LLNeA1oUCGc
To these much more sturdy machines, seemingly taking their sweet time scratching away:
https://www.youtube.com/watch?v=F5Jy5cJscXU
https://www.youtube.com/watch?v=WatC-mihuoA
https://www.youtube.com/watch?v=Psr9Yt49grwLast edited by bluesking; 18-04-2019 at 11:09 AM.
The Following User Says Thank You to bluesking For This Useful Post:
18-04-2019 #2
Hi bluesking
I can see why you want to go for larger cutters and for roughing I would agree, however there is another factor to maybe consider dependant on the guitar design/type you are looking to machine. I'm sure you're aware that most routed pockets on say a Les Paul or Telecaster are a. imperial, but b. also are designed for a set of cutters that have certain corner radii e.g. 1/8 inch which means using a 1/4 inch cutter for most humbuckers. So you may be able to rough out the pockets with an 8-12mm cutter, but will have to do a tool change and a clean up operation with a smaller cutter to clear out the corners.
Also I am using 70v nema 23 steppers on my machine and it easily goes to 15mm depth per pass and I could make that 20mm without too much if any additional tool wear - see here: https://youtu.be/WVf5J8XytSA
BTW if you want the CAD for a "normal" Tele I have that linked in video #9 of the series above. There's a thread on here somewhere as well, as it was a kind of community project.
ChrisLast edited by Washout; 18-04-2019 at 11:06 AM.
My CNC Projects: https://www.youtube.com/imadethisoncnc
The Following User Says Thank You to Washout For This Useful Post:
tooling for hardwood
By BobE in forum Woodwork DiscussionReplies: 2Last Post: 02-12-2018, 10:27 AM -
FOR SALE: Conect 121 CNC Lathe (s)! Ex High School.
By DMY in forum Items For SaleReplies: 8Last Post: 01-11-2018, 11:45 PM -
WANTED: SCHOOL DT Dept needs basic Denford or Roland router running 2D Design
By scoutcentre in forum Items WantedReplies: 1Last Post: 31-01-2018, 09:53 PM -
FOR SALE: Various Items of equipment for sale from a Barnsley Secondary School
By DLODGE in forum Items For SaleReplies: 4Last Post: 07-08-2012, 06:53 AM -
Hardwood Supliers?
By Stickio in forum Marketplace DiscussionReplies: 3Last Post: 06-01-2011, 11:21 AM
