Thread: Passivation
    Thanks for the suggestion of Frosts - I'd forgotten about them. Sadly although they do a very interesting electro-passivation kit it's only for zinc :-(
  2. The Following User Says Thank You to Voicecoil For This Useful Post:
  3. #2
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,987. Received thanks 373 times, giving thanks to others 9 times.
  4. The Following User Says Thank You to m_c For This Useful Post:
  5. #3
    Had a little look into this and it seems that Citric Acid can be used instead of Nitric Acid(link) but you would still have to put a protective coat over that so it looks like the etch primer would be a better solution,Just had a check in the shed, the Manor Paints is the Chromate(yellow base) that i prefer but Chromadex do a none Chromate etch if you prefer that.I got this for refurbishment of Spilka H type window hardware as they are made from mild steel then passivated and clear coated but this deteriorated after about 10 years, just out of interest where are you located, i am near Ulverston.
    Hope that helps.
    Regards
    Mike
    https://www.amazon.co.uk/Citric-acid.../dp/B00GOT02C2
  6. The Following User Says Thank You to mekanik For This Useful Post:
  7. #4
    Hope that helps.
    Regards
    Mike
    Thanks for that Mike, but I really wanted a simple chemical passivation process (i.e. just dip it) rather than some kind of painting. BTW, I'm just over the hill from you in Broughton, nice to find someone else up this way - one often feels a bit out on a limb living up here!
  8. The Following User Says Thank You to Voicecoil For This Useful Post:
  9. #5
    Don't know if it's still operational, but there used to be a metal finishers(Hemsworth) @ Salthouse Mills, but Bill passed a couple of year ago, his brother Bernie might have taken it over, try Yellow pages, they used to do Cadmium plating @ the time i remember, they might have a solution for you.
    Regards
    Mike
  10. The Following User Says Thank You to mekanik For This Useful Post:
  11. #6
    Cheers Mike, I'll see if I can find them.
  12. #7
    Nearest i can find is Carlisle
    http://www.sbmcoatings.com/
  13. The Following User Says Thank You to mekanik For This Useful Post:
  14. #8
    Aye that's the thing I found, but it seems to be for zinc plated items rather than for ali.
  15. The Following User Says Thank You to Voicecoil For This Useful Post:
  1. Aluminium passivation - for aluminium to be used outside
    By CHudson in forum Metal Finishing Techniques
    Last Post: 06-04-2011, 09:18 PM
