Thread: DIY ATC Spindle
19-02-2020 #13
Yes you can use a threaded drawbar with an ATC system. The “drive dogs” shouldn’t actually be doing any torque transfer as such, so they can safely be removed. That means you don’t need to index the spindle for tool changes. That’s how the Fadal ATC works on my Shizuoka AN-S. Makes the system design so much easier...
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
