Thread: Luthier CNC
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 19 Hours Ago Has a total post count of 804. Received thanks 101 times, giving thanks to others 176 times.
    Hi Bluesking
    Broken drills/taps in non ferous materials can be dissolved using Alum solution.
    https://www.google.com/url?sa=t&rct=...9aX0rtzdbxJhZP
    Also when tapping go with the recommended size from your Zeus book ie 4.2mm but use a solid(no flute's) spiral tap.
    Regards
    Mike
    I also used Alum see this post #11 http://www.mycncuk.com/threads/8903-...highlight=alum I am not sure if there are different strengths of Alum
    The best taps I've found for through holes in ali are the blue ring spiral point types like this:
Name:	Europa spiral point blue ring.jpg
    They're made specially for aluninium, the interrupted thread higher up seems to help with binding. Typically I've found you can tap a hole in 12mm plate in 3...4 seconds with one of these in a cordless drill with some cutting fluid. For blind holes as Mekanik said you need to use a spiral flute tap (to get the chips out), again I've found the blue ring types are marginally the best.
    mekanik's Avatar
    This might be of interest
    http://www.europatool.co.uk/threading/application-taps
    Regards
    Mike
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    In a nut shell for taps-
    Spiral Point - Only good for through holes, as they push the swarf forward through the hole.
    Spiral Flute - good for blind holes, as the swarf comes up around the shank, but are more prone to binding if the swarf doesn't clear.
    My preference is always spiral point, as they're the stronger option.
    If you're only going through relatively thin section, I'd avoid the interrupted flute ones Voicecoil posted a pic off, as a bit inadvertent sideways pressure with only two or three support flutes engaged can quickly jam the tap and snap the tap/rip the threads out the hole.
    As always, lubrication is key. For tapping aluminium, a drop of good quality cutting oil is essential to stop things sticking.
    There are also threadforming / roll forming taps which can give a stronger thread in aluminium, but drill hole size is very critical, so I would advise against them unless you can control the hole size well. Undersize and the tap will quickly jam, oversize and you won't have much of a thread.
