Thread: Luthier CNC
  1. #18
    The best taps I've found for through holes in ali are the blue ring spiral point types like this:
Name:	Europa spiral point blue ring.jpg
    They're made specially for aluninium, the interrupted thread higher up seems to help with binding. Typically I've found you can tap a hole in 12mm plate in 3...4 seconds with one of these in a cordless drill with some cutting fluid. For blind holes as Mekanik said you need to use a spiral flute tap (to get the chips out), again I've found the blue ring types are marginally the best.
