Thread: Luthier CNC
    As I've just mentione elswhere, an RCD in your mains supply offers no protection against shocks from the output of your VFD. Don't take risks with the safety earthing of your spindle.
    I haven't taken any risks: the spindle is earthed. Thats the reason why I had to introduce a ground loop to make my z probe work how I wanted and still be safe - at the cost of some potential interference...
    It's a basic catch 22 - and the reason why many valve amps have a ground lift switch. Always seems a bit dangerous to me to leave it in the hands of the guitarist to decide what is safe! But it's there when you use multiple amps and you know they are all on the same mains circuit yet the ground loop is causing noise to get in the system.
    We should probaly start a new thread to start talking about multiple amps, Brian May, whether Russian ECC83s are better than the Chinese, using CNC machines to build guitars.....................
    Kit
    Kit
    For sure. And by the way, the best ECC83s are dutch: amperex bugle boys. They might not be as well known as mullards but they are cracking. You can find them for under £10 each - if you know where to look :)
