I was initially thinking along similar lines for guitar building but I have since decided to build my own: http://www.mycncuk.com/threads/12727...359#post108359
As you already know the C-beam is too small of a working area for guitar necks. The biggest problem with the C-beam for me was that, because it is a fixed gantry, you don't have the option to tile the work (e.g. cut the lower half of the neck, move the stock, then cut the rest). If you want to make a full neck you're going to have to make the machine big enough to do everything in one go.
To make the C-beam bigger you're basically going to have to redesign the whole thing - you're going to have to put a lot extra of money and time into it to do that.
Another option in a similar price range is something like this used OX frame:
https://www.ebay.co.uk/itm/OX-openbu...s/192880636458
That will just about cut a whole guitar neck, and you can tile with it, so you could do a bass neck in 2 parts.
If you want something more rigid and ready out the box something like this might be better, if you can up the budget:
https://www.omiocnc.com/products/x8-2200l-usb.html
Or you can obviously build you own, but as I'm finding, that will chip away on your time and money much more.Last edited by bluesking; 26-04-2019 at 03:43 PM.
26-04-2019 #2
Have to agree with this - at the very least you're going to need a new ballscrews on both axis, and new profiles, by which point you've already spent the same again on the machine. Thats not even starting on what you need to do in order to do this job properly - I'd argue your money and time is better spent on a second-hand machine already of the right size and capability.
Choosing right CNC
By rockstardmtb in forum Machine DiscussionReplies: 0Last Post: 09-04-2019, 09:59 AM -
Choosing a machine
By Tony B in forum Machine DiscussionReplies: 1Last Post: 15-12-2018, 09:25 AM -
choosing a 240v single pahse cnc milling machine
By Jeromep in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 18-09-2015, 02:24 PM -
need help! choosing right kit
By msacnc in forum Gantry/Router Machines & BuildingReplies: 26Last Post: 17-09-2014, 09:41 AM -
choosing a spindle.
By charlieuk in forum Spindles & Drive MotorsReplies: 15Last Post: 16-01-2014, 08:18 AM
