Page 2 of 2 FirstFirst 12
    Yes my bad
    No problem, i appreciate the help :)
    Sent from my SM-G920F using Tapatalk
    Question for anyone that knows, i have now bought a contactor to control the 240v side or the toroidal power supply. The coil is 24v and it is wired up and functioning but it seems to get very hot! I have disconnected the 240v to verify its the coil side that is hot and it is so my question is whether this is normal? I first noticed it when I smelt it!
    It should not run that hot
    double check your not connecting 24V DC to a 24V AC coil !
    which contactor do you have ?
    John
  4. The Following User Says Thank You to john swift For This Useful Post:
  5. #14
    I didn't even think you'd get a a 24v a.c. coil! Hmm...mayve it is now that I've had another look, it says 24v 50hz. :(
  6. #15
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Yes I have seen that before. 😡
  7. #16
    The resistance of a 24V AC coil is too low to limit the current to a safe level when its connect to 24V DC
    Connecting a DC coil to AC will reduce the current and may not pull in the contactor
    and the eddy currents in the magnetic core heat the core
    (usually laminated cores for AC & solid for DC)
    Its a few year ago I last bought contactors from RS conponents
    The klockner moeller contactors I bought had 48V dc coils ,
    I clipped 2 contactors onto a mechanical interlock for 3 phase motor direction control
    (to make it impossible for both contactor to make a connection )
    From what I remember the coils available was
    24V DC , 48V DC , 24V AC , 48V AC , 110V AC , 240V AC or 420V AC
    John
  1. Wiring home and limit switches
    Last Post: 18-11-2023, 06:14 PM
  2. Wiring Limit Switches, and can it be done with my control box?
    By ravihotwok in forum General Discussion
    Last Post: 22-06-2017, 11:23 PM
  3. Wiring 3 wire proximity switches in series
    By mikem in forum General Electronics
    Last Post: 02-05-2016, 09:33 AM
  4. Wiring limit switches
    By Janste in forum Spindles & Drive Motors
    Last Post: 10-02-2015, 10:37 AM
  5. Proximity Sensors as Limit Switches ?
    Last Post: 03-10-2009, 07:04 PM
