Page 2 of 2 FirstFirst 12
  2. The Following User Says Thank You to Crunch For This Useful Post:
  3. #12
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 12 Hours Ago Has a total post count of 801. Received thanks 101 times, giving thanks to others 176 times.
    Hi Paul
    Others (who have actually built a machine) would be better to give advice regarding gantry weight ect, but as you say you want it as rigid as possible and also not too heavy.As a general rule the axis are usually X longest Y gantry and Z for the virtical. our cousins from across the pond sometimes do it differently, it,s a pitty you didn't open a discusion before you started your build as if you are strugling with floor space you had the option of making a semi vertical layout.
    Good luck on whatever you decide, under no circumstances purchase any of your electrical gear before you have your design set, the weight of the gantry is an important factor regarding motor choice, and it would be better for you offer your design up for critique, the lads will put you right regarding motor selection.
    As you want to use the box section you have already purchased for the gantry i would do as you said and put a length of flat bar inside across the narrow section, drill a series of holes in the box section and stitch it to the flatbar so get the same effact as two square sections, won't be as rigid as the latter but should be better than the box section as it is now.
    Regards
    Mike
  4. The Following User Says Thank You to mekanik For This Useful Post:
  5. #13
    Thanks Mike
    Sent from my SM-G900F using Tapatalk
  6. The Following User Says Thank You to Crunch For This Useful Post:
  7. #14
    The convention for axis labelling is:
    Standing how you will use the machine:
    X is left and right
    Y is towards and away from you
    Z is up and down
    It is this way because that is how you design things in CAD etc. It probably originates with labelling of graph axes.
  8. The Following User Says Thank You to pippin88 For This Useful Post:
  9. #15
    You want diagonal bracing in the tube, not a horizontal plate. This can be done by stitch welding vertical plates within the tube at a few places and welding on end plates.
    The gantry is subject to torsion. Diagonal bracing is much more effective.
  10. The Following User Says Thank You to pippin88 For This Useful Post:
  1. NEW MEMBER: Not so new introduction
    By Rebekah_harper in forum New Member Introductions
    Last Post: 20-07-2016, 03:57 PM
  2. NEW MEMBER: Introduction
    By mrpeja in forum New Member Introductions
    Last Post: 23-12-2010, 04:59 PM
  3. NEW MEMBER: introduction
    By john696d in forum New Member Introductions
    Last Post: 08-12-2010, 01:38 PM
  4. NEW MEMBER: Introduction
    By madd in forum New Member Introductions
    Last Post: 04-12-2010, 01:31 PM
  5. NEW MEMBER: Introduction
    By eltel in forum New Member Introductions
    Last Post: 08-09-2009, 11:31 PM
