29-04-2019 #9
The only thing a larger spindle can do for you is add mass, there is no magic in spindle capacity itself which can reduce vibration, only mass and rigidity will do that.
You can experiment with added mass with your existing spindle, there will be a sweet spot for each set of cutting conditions but more mass will always give some improvement as it's inertia will resist cutter deflection.
Looking at your video again your spindle mounting system could be massively improved by adding a second identical mounting ring and having the two as far apart as possible, your current mounting arrangement has almost no triangulation and will be a point of flex in the system.You think that's too expensive? You're not a Model Engineer are you? :D
Fusion 360 Cloud Crashes: Fixes Coming
By Lee Roberts in forum Fusion 360Replies: 6Last Post: 23-12-2016, 01:07 PM -
I need a Good CNC Machine for cutting letters out of wood for under 800.00
By theceo in forum Machine DiscussionReplies: 6Last Post: 02-04-2016, 12:48 PM -
RFQ: Wood CNC routing service (wood Letters)
By coujin in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-02-2015, 03:35 PM -
Milling Continuous Profiles?
By Tenson in forum DolphinReplies: 3Last Post: 15-02-2012, 04:53 PM -
Aluminium Profiles
By wizer in forum General DiscussionReplies: 10Last Post: 10-03-2010, 11:41 AM
