26-10-2019 #12
You've got till the end of Jan - I'll give you good odds on that :)
Looks good - Although read the VFD manual about switching it on and off with a relay - mine specifically says not to. I'm hoping UCCNC will drop the spindle enable when it receives an E-Stop command, but have yet to test this.
I'm also planning to use FA/FB/FC for a fault signal feedback from the VFD to the UC300eth - I figure I'd rather use this function for stopping the CNC when the spindle faults (and therefore stops rotating) than running the water pump - which can just be run continuously anyway. I don't like the idea of the spindle stopping and then the CNC trying to force the bit through stock.... that sounds like a bad situation.
Cool. Also look for an electronics cab which will help you start placing components etc. I used Tempa Pano - rather cheap, but not perfect quality.
Don't forget to look into breakout boards. I really like my UB1. May as well buy them at the same time. Why is the UC300 time-sensitive? Usually its best to get the mechanicals in order and built before starting to buy the big ticket electrical components - you never know whats just round the corner in terms of new models, and you'll end up ticking away your warranty while you're still building.
Looking forward to it! :)
BUILD LOG: Desktop build with zero budget. Critique my design please?
By Nealieboyee in forum DIY Router Build LogsReplies: 16Last Post: 25-07-2017, 03:50 PM -
NEW TO CNC - Starting design and so forth
By PSG in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 19-03-2014, 10:30 AM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
