21-07-2019 #23
I have to completely agree, without all the advice from the people here I would not even have remotely come this far!
Currently I am reading through some of those build logs to hopefully find a good one about the PSU section of the build. All the electronics are pretty clear to me, but the interface between machine voltage and net voltage. I see that a lot of people build their own transformers, which is definitely an option, but I am still looking into that. Most of what I am still missing on the machine side mostly related to the spindles and which I want to have in hand, before commiting there.
If all goes to plan, I thus want to sort out the electronics over the next two weeks and then move on to buying parts. That is when I want to make a final pass and move on to the next step, if there is not a flaw that needs sorting out. Once I do move on to buying, I will probably make a proper build-log post as well.
I am also scouring the posts for something related to cutting forces and speeds, to be able to dimension the steppers. As far as I could gather from various posts here, I would pretty much always like to use the steppers in bipolar parallel connection, and using that, getting all the info and all the steppers I can find, I have not found a single one, so far, capable of driving two 2510 ballscrews at 7.5mm/s rapids... who would have thought? :D So I am thinking about moving to a one-stepper-per-screw setup. With that, however, I am still looking at one of AndyUK's first pieces of advice to me and hesitating. So I am thinking about putting a timing belt between the two motors to synchronize them as well, but I don't know if that is a good idea or if it even works. Looking at the motor calc sheet, however, there is a motor that would permit me to get 6.1m/s rapids with only a single motor, as well as letting me cut at 2.1m/s with 50N of cutting forces. But then again, I am still searching for posts on speeds to look out for.
BUILD LOG: Desktop build with zero budget. Critique my design please?
By Nealieboyee in forum DIY Router Build LogsReplies: 16Last Post: 25-07-2017, 03:50 PM -
NEW TO CNC - Starting design and so forth
By PSG in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 19-03-2014, 10:30 AM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
