    I'm still aware I haven't gone through your calcs yet... Finding time is hard! Sounds like with the design changes though I may wait a little longer :)
    I second Washout's comments about the CS labs stuff, looks brilliant. The thing that put me off was that the base model is only 4-axis, and it doesn't handle slave axis homing native-ly (although there are decent workarounds posted on here). Anything more than the base model is horrendously expensive, and I wanted future expand-ability to add a 4th axis which is gone if you use the 4th for a slave - but you avoid both of those issues by having a connecting belt and single motor.
    Also, on the four rails idea, I think you'll definitely end up spending a few days becoming best mates with your dial gauge - but it could pay off in the end?
    First impressions on the redesign; I think your CAD is coming along nicely, really shows. I do have a few concerns though:
    • I question the Z axis travel length and why the plate is so large - Don't forget you'll have a bit attached to the end of your spindle, and its going to have to be quite a long bit to make use of your Z travel. I've got 18cm, and honestly, its probably far too much, most of the time you're really only needing to cut say 18mm plywood! The distance between the bed and the gantry looks huge - All that Z extension reduces the rigidity of the machine. Have a think about what you really need - can it be acomplished in other ways, such as an adjustable height bed or overhang section which keeps everything stiff for the majority of the time, but when you need to use the router on something large you can?
    • How are you going to assemble the Z axis? Look through the design, building it up step by step, and imaging when you will or won't have access to each screw and what that implies. I've got my ballscrew and motor on the fixed bit because I can easily get to the four screws holding the ballnut onto the Z plate, undo them, then slide off the rails. Your design looks a little harder to physically assemble.
    • The C beam - how are you going to attach those profiles to each other? Any weakness here will be quite problematic and you've got two joints which need to be constrained.
    • 10mm of steel looks quite beefy for a side plate, but 3mm seems quite weak in my head. I realise its intentional, I'm just not convinced!
    A few comments I would have from your last set of design drawings are:
    - whilst 4 rails looks like a good idea, you will have a devil of a time aligning them I expect. Maybe 2 rails of a larger size might be better?
    It seems I have messed up my explanation here. I do not plan on using four rails, but instead three. Two linear HIWIN-style rails on one side, mounted atop each other. The other side only has one rail, and a different type, namely the cylindrical Igus-Style rails that you also often find in 3D printers, like the Prusa MK3. That will still take some work aligning, I get that, but it should technically work to help let the machine compensate. I know, technically is a nice word, but practically often takes precedent :D I have added another picture, with the HIWIN rails in their place, to hopefully make that more clear.
    [*] 10mm of steel looks quite beefy for a side plate, but 3mm seems quite weak in my head. I realise its intentional, I'm just not convinced!
    This one's along the same vein, and it honestly also seems off in my head, but the math should check out there. Ultimately, the sideplates don't cost much to make, especially not the smaller one on the left, so if it turns out to be a problem, I can change it around without much of a problem.
    [LIST][*] I question the Z axis travel length and why the plate is so large - Don't forget you'll have a bit attached to the end of your spindle, and its going to have to be quite a long bit to make use of your Z travel. I've got 18cm, and honestly, its probably far too much, most of the time you're really only needing to cut say 18mm plywood! The distance between the bed and the gantry looks huge - All that Z extension reduces the rigidity of the machine. Have a think about what you really need - can it be acomplished in other ways, such as an adjustable height bed or overhang section which keeps everything stiff for the majority of the time, but when you need to use the router on something large you can?
    Something like that came up when talking to my colleagues as well, today. We came up with inserting angles to hold up the sides, which could be removed if needed, but when there, would make it a bit stiffer. I really quickly added one in the picture above, highlighted in pink. Imagine four of those in the corners.
    Could you maybe elaborate on how an adjustable Height bed and that "overhang" would work? I have a hard time imagining those two.
    [*] How are you going to assemble the Z axis? Look through the design, building it up step by step, and imaging when you will or won't have access to each screw and what that implies. I've got my ballscrew and motor on the fixed bit because I can easily get to the four screws holding the ballnut onto the Z plate, undo them, then slide off the rails. Your design looks a little harder to physically assemble.
    Good shout! On the first look, I should be able to do a similar thing, but with removing the screws of the Z-Ballscrew Bearing Blocks instead, but I will definitely check that again.
    [*] The C beam - how are you going to attach those profiles to each other? Any weakness here will be quite problematic and you've got two joints which need to be constrained.
    I have enough space between the screw and the profiles, to be able to insert some angles to bolt them together (that is going to be some fun fiddling with angled hex drivers, however :D) and I can also bolt them together on the back side as well. With the sled in front, forming a closed frame and additional bolts in the side-plates, that should be enough then, right?
    - Also consider the CS-Labs kit for the controller - many on here use them, including the venerable JazzCNC (which is always a good sign imho)
    With that much of a recommendation, I will definitely take another look. But I must admit, the price of the units, especially compared to the other controllers is quite steep. I might just stick with one of the cheaper ones and maybe upgrade later on. I am managing to stick within my initially laid out budget for now, but I want to also reserve a buffer in that, so that a problem won't throw me off course completely.
    - Proximity switches if they are the type in a threaded housing, will give a nice amount of adjustment for the trigger point - you can do the same with micro-switches, but they then need a plate with slots to mount them to to achieve that
    Yeah, that was my thought. My 3D printer uses a proximity switch for leveling, and needs exactly that adjustment, which also means that it can be calibrated pretty finely.
    Don't worry, no rush :D I am pretty sure I have suitable Y- and Z- Motors, but the X-Stepper is what I am still fiddling with the spreadsheet for. My main problem is how to calculate the thing driving two ballscrews at the same time. I just added a multiplication by 2 in the part of the equation that contains the Screw Inertia.
    While I am busy getting all the detail into the CAD and making sure all the dimensions are correct, a question came up, that I want to ask the collective of experience in this forum.
    This question is, if I can use the chinese linear rails (like these), or if there are any known problems with their accuracy or surface finish that makes them bad alternatives? I am asking this, because of just how much cheaper they are to get. Same question goes for the ballscrews.
    Hi Chrono
    When I first saw this design, I couldn't help but think that was far, far too flimsy
    Now with your explanation of the gantry driven from one side only (above)......it's getting worse!
    Don't forget that to reduce cutter breakage, wear, chipping, improve accuracy and surface finish, the whole machine must be as rigid as possible and subject to as little resonance and vibration as possible. This is why machines traditionally are made in cast iron or synthetic granite (Granitan etc) that are "dead" materials, they don't "ring".
    In the latest design, you are driving the gantry from one end only (and I still can't understand what the benefit is of the lower ballscrew). This goes against evrything that you will read on this forum, "ballance your forces", " place the cutter forces in between the bearings" etc. It is akin to digging a hole in the garden whilst standing on a diving springboard!
    And the 6mm thick gantry sideplate.......
    Compare yours
    with this from Boyan.
    Yup, Boyan's is built like a brick sh!thouse. Some may say that it's over the top, but I bet it does the job!
    Or just taks a look at Andy's build
    http://www.mycncuk.com/threads/11552...-2x1-0m-Gantry
    Sorry if I seem somewhat hard on you but I don't want you to waste time and money unnecessarily.
    Any other of you forum guys have a comment?
    Good luck Chrono, you'll get there.
    Martin
  5. The Following User Says Thank You to MartinS For This Useful Post:
  6. #5
    Quote Originally Posted by MartinS View Post
    Hi Chrono
    Martin
    First up, I am still driving the gantry on both sides. Just one side is resting on two HIWIN rails, while one is resting on a linear bearing on a smooth steel rod-type rail. Here is the model if you want a more detailed look.
    Secondly, I appreaciate the feedback, but what exactly are the problem areas here, what needs to change? Most design decisions come from advice I got from the mechanical engineers at my place of work, some of which have been building similar highly-dynamic gantry machines for Zeiss, taking measurements. This is also where the rail division comes in. Looking back at my technical mechanics textbook, this should protect the linear rails from having to take on torque, while still handling static loads. So that is the reason why. I, obviously, cannot tell you if that will work or not, but that is why I am here, after all :D
    Edit: Some pictures to illustrate the whole X-Axis setup, excuse the dreadful mouse-written writing.
ID:	26064Click image for larger version.
    Another constraint I am having, is that steel box section, for example, is pretty difficult for me to work with. I do have access to people who can weld for me, etc., but I pretty much have no way to assemble the machine where I need it to, in my workshop, or get it out of there, once assembled. It is on the first floor in my garage, with the only access being a small staircase barely wide enough for one person. Hence the aluminium profiles. If that is a no-go, the only other option i have, is a small hatch, not even high enough to kneel in, which will severely limit the machine's size, overall.
    Then there is also my budget, which is pretty close to being used up, even with that design.
    On a side note: do you have a link for the post from boyan? I would like to further read up on that build.
    Thanks for the feedback,
    Chrono
  7. #6
    Chrono, apologies for missing the second ballscrew, that makes a big difference. You at least have a brick under the end of the springbard
    Most builders here use rails both ends of the gantry to as best they can, constrain "flexy" elements (don't forget, most materials are looking for any excuse to bend, twist or vibrate).
    When your spindle is cutting at the 6mm plate end of the carriage, Hiwin rails will help resist the twist on the gantry better than the Igus ones. And either way, increasing the distance "C" between them will help.
    I mentioned Boyan Silyavski's build
    http://www.mycncuk.com/threads/6457-...my-first-build
    not to push you towards steel, Al is fine, but to demonstrate by design, reducing the chance of flex and vibration.
    Re. the 6mm gantry end, I think that you mentioned that it is to "...let the machine compensate". I guess that you mean "to accommodate assembly/build errors" One way that others achieve this with rigid side rails and substantial side plates, is to mount the Hiwins on the top so that with clearance holes in the sideplate mounting, they can find their own best position on the carriages. See AndyUK's approach. Again, I am not pushing you to change, just showing other approaches to your best friend "rigidity". Also, bracing across the end is another approach.
    I have a background in manufacturing with machining centres and lathes with capacities up to 1200mm, precision grinding and measuring with CMM's in controlled environments. Whether it be a CMM or a cutting machine, we want to be assured that the probe or cutter is in a specified and known position. The difference betwen the two are the forces in the system. Those in a cutting scenario being far greater....
    Regarding the side rails, it wouldn't harm if you added one or two extra pillars and fillets per side. Also, bracing across the end is another approach.
    I hope that this post is more positive than the last one. There are soooo many ways of getting "there" and you are nearly there, Y and Z look great.
    Crack on lad......
  8. The Following User Says Thank You to MartinS For This Useful Post:
  9. #7
    That cleared things up a lot, thanks! I gotta admit, for a second there I thought the aluminium profile construction was "out of the question" entirely, so to speak, so I am relieved on that end
    I also thought about putting in some more support pillars, so I will do that. They are so short anyways, that they don't cost enough to not put in. regarding a crossbar, I could easily put one in in the back, without even impeding X travel, since the gantry's body will sit on top of it, and it will run out of rails before the spindle would even get a chance of touching it.
    You also put in angles in the middle pillars. I definitely see their point, but I am looking at them protruding into the machining area, so I might try and make them removable, with accessible screws, so I can put them there for smaller projects, and take them off, when I need the space. That way I get the best of both worlds, so to speak.
    Also, regarding the distance between the bearing blocks on the X: That is one of the parameters I can just change on-the-fly, so changing that is easy-as-can-be :D I am mostly leaving it as a kind of place-holder while I am working on getting everything into place. Afterwards I just need to open the variables panel, and go to town dialing everything in.
    Finally, on the topic of the thin plate, and the associated double-stack of rails, with one opposite linear rod bearing: It is not that much about building tolerances (I mean I am not perfect, so there will be those), but also things like thermal expansion, and so on. I am going off of the one lecture in mechanical engineering I got in my electrical engineering course, but with the linear rails on both sides, you would enter statically-overconstrained territory, which is exactly the reason for me to go for the steel rod and linear bearings, exactly because they cannot take on torque. however, if this ends up not panning out, changing the lower rail over, would be quite easy, since all i would have to do is cut down the gantry extrusions by 7mm (which the linear bearings are higher by, compared to the rails and bearing blocks), or shim it with another plate, and swap in one of the rails, not a big hassle.
    And I found a picture of the Zeiss machine I was talking about: Click image for larger version.
    As you can see, it has a similar design, with rails on existing on the right, while the left either rolls on the table or hovers on it, I cannot remember if the hovering was another machine, though, and a quick search did not throw up any info. Either way, looking at the YZ-Plane, one end is fixed, while the other is allowed to expand/move. Of course, that does not mean that it works the same for me, but I thought I would post that for illustratory purposes :)
    I also plan to add some slits in the plates themselves, serving as holes for potential cross-supports, should it turn out that they are, indeed, too bendy. I will attach a picture hereafter, looking at the right plate, with such a support in vibrant pink. I am afraid that picture can explain this much faster than I could in words. Those plates should serve to add further rigidity, in the same sense as the bends all around the Z-Axis do, and if I find I need them, I can put them in, weld them in place, and go from there.
    (also seen in the picture, in the front left of the machine, the WIP of new angle plates. The right is not in yet, because I still need to move the right ballscrew vertically in between the two rails)
    What do you think of those measures to address these problems? Is there anything else I should be doing to increase the rigidity?
  1. BUILD LOG: Desktop build with zero budget. Critique my design please?
    By Nealieboyee in forum DIY Router Build Logs
    Last Post: 25-07-2017, 03:50 PM
  2. NEW TO CNC - Starting design and so forth
    By PSG in forum Gantry/Router Machines & Building
    Last Post: 19-03-2014, 10:30 AM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
