Because if you hadn't had a good skimming before I was going to suggest a very similar prognosis to the one you've just come up with! Though it might be more than a matter of the rails being bowed - obviously they're less stiff in the middle than at the edges, so the spindle can move about more.
30-04-2019 #2
Personally I thought at first that the spindle wasn't quite perpendicular to the bed and needs minute adjustment. It looks to be spot on when going in what ever the directions are to the left and right of the pic (top to bottom of pic), whereas you can see tiny lines/ridges on the cuts that go from left to right of the pic (the problem areas).
cnc spoilboard
By dfox1787 in forum Machine DiscussionReplies: 19Last Post: 28-01-2018, 06:17 PM -
Surfacing bit and t-slot bit
By eurikain in forum Workshop & EquipmentReplies: 11Last Post: 25-04-2016, 01:58 PM -
Spoilboard Surfacing - What tool(s) do you use?
By Mad Professor in forum Tool & Tooling TechnologyReplies: 6Last Post: 12-01-2013, 11:55 AM -
Strange problem, possibly missing steps?
By Philly in forum Chinese MachinesReplies: 5Last Post: 26-10-2012, 06:36 PM -
New engine-making tool should result in more fuel-efficient cars
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 11-10-2012, 01:32 AM
