Thread: Gantry advice please
04-05-2019 #12
Your X axis is quite long for 16mm - You'll get a 12mm root diameter on these, which means assuming you use a BK and a BF, you'll have a max speed of 1000rpm before whipping. With the 10mm pitch you're okay because it sets your max rapids of 10m/min - definitely wouldn't want to go 1605 though! A 20mm screw instead will give you a max rpm of 1260 which bumps your possible rapids up to 12.6m/min, but will take slightly more power from your motors.
The Y axis gives you a max rpm of 1800, which is fine.
Need advice on gantry design
By jcarpenter in forum Gantry/Router Machines & BuildingReplies: 33Last Post: 13-05-2018, 01:51 PM -
Advice and opinions 3 axis gantry for cutting Ply / Hardwoods
By Jeff in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 09-10-2017, 04:38 PM -
Physicist trying to do engineering. Not going well. After advice with 4 axis gantry.
By dr_rob in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 07-12-2016, 11:34 PM -
Fixed Gantry small precision begineer project advice
By yasu in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 17-10-2016, 07:14 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM
