    Well that's a good start to a long weekend - got a ball screw and nut through the post for the conversion of a Sieg SX2.7, specifically for the Z axis. Carefully rolled the nut onto a bit of Ali pipe (bored bar) to rotate it top-to-bottom on the screw, inserted nut in the Z-axis carrier, carefully inserted screw into the column, and dropped it onto the pipe, punching it through into the base of the column - full of grease and cast iron dust and dropping the balls out into the same.
    Oops.
    I might be able to find all the BBs - this was above an open drawer so they should all be in there somewhere!
    Now, as well as the BBs, the three diverters dropped out as well. Each has a different number stamped on the outer wall (the bit that pokes through the nut wall and remains visible). These are the steel diverters, as well, not the plastic ones.
    Question: Is there a sequence (numeric) that the diverters need to be inserted?, otherwise what do the numbers signify?
    Next... any good hints on repacking?, I've filled the races with silicone grease, will leave it to tomorrow to go tacky (bit thin straight out of the tube).
    Finally, any good swear words?, I think I've exhausted all the ones that I know.
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,342. Received thanks 618 times, giving thanks to others 82 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Its a good learning curve. They are not to bad to get back in, not as hard as the blue smoke that comes out of some electronics
    Have you seen this https://forum.linuxcnc.org/51-ot-pos...it-a-c7#130764
    Clive - cheers - that's a pretty good video you've linked to - had the wife giggling in the corner listening to men packing their balls.
    Next bit of fun... I tried printing a packing tool to help on this job (I do still have one spare ball nut somewhere)....
    Isn't that cool!!!
    Now, look closely at the thread rotation.
    My how I laughed.
    Another 3 hours to print this the correct way.
    Oh, you might want one of these https://www.sparkfun.com/products/retired/10622
    Isn't that cool!!!
    My how I laughed.
    In time you printed that you could have packed 10 ball nuts. Nice find on the kit though
    I don't think the numbers matters, I've never followed any convention resulting in conviction.
    I've re-packed quite a few of these so if you get stuck and want to send it to me only the postage cost is involved.
    I do the same and load the nut up with enough grease to keep the balls in place but not to much you cant see what your doing, you can use the screw or a nicely sized pipe to keep them in place as you re-load each circuit.
    1605 balls are 3.175mm (1/8") size
    1610 balls are 2.778mm (7/64") size
    1605 has 3 circuits
    1610 has 2 circuits
    17 balls in each circuit.
    .Me
    Cheers Lee... the irony is that I had a spare nut - one that you sold me a couple of years ago that's finally found a home in a machine (my original plans for the screw went south). I'll try repacking the other one when I clean the shed up (at the moment the interior is covered in Ali chips & WD40 from the machining of the various brackets for this conversion... not ideal environment for repacking!)
  7. The Following User Says Thank You to Doddy For This Useful Post:
  1. RFQ: Ballscrew bearings repacking help
    By Maravedis in forum Projects, Jobs & Requests
    Last Post: 04-04-2016, 01:01 PM
