Hey “yall”
I’m looking at limit switches for my new machine, has anyone used Proximity Sensor’s on their machine and is there a brand that would better for this job.
Also would the door sensors you find on house alarms be any good/reliable for this kind of thing?
Thanks,
LeeLee
02-10-2009 #2
Bad Juju.
prox sensors not accurate/repeatable enough (at a price you can afford) and get a speck of swarf, wood chips etc etc on the target and you lose any accuracy . Why you swimming against the stream man? Go with the flow, go mechanical, tried and true tech. Or optical if you like although they suffer similar problems to proximities.
You just trying to be different Mr. Lee?
Jeff.Last edited by Smiler; 02-10-2009 at 07:43 PM.
02-10-2009 #3
I'm going magnetic with my limit switches. Home switches won't be repeatable (haven't decided what to do with them), but since limit switches are, for me, just in case of emergencies, it would be fine.
Plus I'm not cutting metals, so not too worried about swarf.
As a related aside, I do some electronics for a crop spraying company. My electronics controls a 4-wheel steering system, where it switches between 2-wheel and 4-wheel steering. When switching from 4 to 2, it can only do this when the front wheels are aligned. They use magnetic sensors for that with a thin plate bolted on to the steering rack. The magnetic sensor picks up the edge of the thin plate, and is accurate to about 2mm.
02-10-2009 #4
Hi
we use inductive sensors from Wenglor or Baluff, seem to work fine.
mike
www.techservcnc.com
02-10-2009 #5
Don't confuse limit switches, which are for emergencies, with home switches which need to be accurate and repeatable. Personaly I'd stick with mechanical switches since it is much easier to make these fail-safe compared to purely electronic ones.
03-10-2009 #6
Proximity limit switch problems
By davrich in forum General ElectronicsReplies: 16Last Post: 12-03-2018, 01:58 PM -
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Proximity Switches
By kingcreaky in forum General ElectronicsReplies: 20Last Post: 23-10-2013, 01:30 PM -
Limit Switches
By Leadhead in forum General ElectronicsReplies: 1Last Post: 16-10-2013, 10:41 AM -
Proximity Sensors / Mach3 not showing
By dudz in forum General ElectronicsReplies: 21Last Post: 15-06-2013, 08:47 AM
