    Be gentle - first post here ... :)
    I have a Sieg KX3 running on a parallel port via Mach3, and was wondering
    a) what are the pin connections for the 1/4" jack for the probe?
    b) is there a way of making a rudimentary probe?
    c) how to then set up Mach 3 to use the probe?
    Documentary info, both on the KX3, and Mach 3 all seems a little vague/non-existent that I can see regarding this matter.
    Thanks in advance for the help :)
    z3t4's Avatar
    Lives in Manchester, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 9-10 years. Has a total post count of 31.
    I'm guessing pin 15, but I'd be tracing it back to the breakout board.
    HTH
    Regards,
    John.
    Ta ... I guess I’d be quicker doing the same to mine, take the side off and trace it (unless anyone has a schematic?)
    Assuming that it has a standard tip and sleeve jack, the sleeve is probably grounded and the tip is the active input. Easy way to test is to open the diagnostic screen (assuming it's available in the KX3 screen set), and look for the "digitise" light while you ground the probe input - it should go green when touched to ground. Probes / edge finders are easy to make - see here;
    https://www.model-engineer.co.uk/alb...47864&p=794324
    Quote Originally Posted by JohnHaine View Post
    Just to add - I would hope that in a ready-made machine and controller they would have configured the ports and pins, but in case they haven't, or even if they have, you may need to open config/ports and pins/... and check which pin "digitise" is assigned to and what the logic sense is. I think pin 15 is the "standard", and logic low = probe touching is the easiest to handle since an isolated probe tip touching a grounded workpiece pulls the probe low. Most BoBs should have a pull-up already. Renishaw type probes though have a normally-closed switch that opens on contact, so you would need to set the logic sense to active high. The pictures in my post above are of a rigid 10 mm dia probe for edge finding and a tool height setter which has a spring-loaded isolated carbide button at a known height that is grounded when the tool touches it. My probing routine then takes the tool up to 50 mm above the table surface.
  1. ATC Spindles air connections inquiry
    By Noplace in forum Spindles & Drive Motors
    Last Post: 08-04-2021, 07:57 AM
  2. Need help with % probe
    By Sp00kie13 in forum General Discussion
    Last Post: 11-10-2018, 03:45 PM
  3. Edge Probe + tool length probe on same input
    By Noplace in forum General Electronics
    Last Post: 18-06-2016, 11:12 AM
  4. CNC Probe - Tried this one?
    By Davek0974 in forum Machine Discussion
    Last Post: 03-06-2016, 02:58 PM
  5. 2 Machines 1 Switch for the output - Connections
    By Ian Hart in forum General Electronics
    Last Post: 02-04-2010, 02:33 PM
