    Hi, I built my first CNC Router (just a "lousy" MPCNC :)) and got a 0,8kw Chinaspindle and Huanyang VFD2,2kw.
    I created a Waterpump solution using 12V supply.
    I would like to only turn the pump on, when the spindle runs. Therefore I wanted to use the DRV/UPF/DCM connectors switching an external Relay on. I already programmed PD050 and PD051 to "1" but I cannot measure anything between these two ports (no matter if spindle is on or off).
    Now I dont have any clue how I could use these 3 ports for this action?
    The FA/FB/FC Terminals are already used to switch the CNC off by error.
Name:	2019-05-08 22_38_22-Window.png
    As FA/FB/FC are com NC and NO, can't you use the other side to indicate if the pump should run?
    I.e. use the NO for the pump and NC for the error circuit?
    Sent from my SM-G950F using Tapatalk
    The Relay with FA/FB/FC is already in use as an emergency off for the cnc control (motors eg.). Therefore I have to use somehow these Optocouplers.
    As you have only one possibility to program FA FB FC, you cant use two functions with it. When I program it to switch only with an error, then the pump will run always except an error occurs. The plan was to switch the pump on, when the spindle starts.
    I think I'm missing the point here. Can you not simply 'or' the FOR/REV inputs to actuate a relay to switch the coolant pump?
    FOR/REV are inputs ... dont know what you mean.
    So, use the switched inputs to actuate a relay AS WELL as command the spindle to spin... So the coolant pump is driven by the demand, rather than the spindle status.
    I appreciate that this isn't answering your question on the use of the DRV/UPF outputs
  1. What connectors?
    By Neale in forum General Electronics
    Last Post: 07-07-2015, 12:21 PM
  2. switching from steppers to servos - STEP / DIR control
    By dsc in forum Stepper & Servo Motors
    Last Post: 18-06-2014, 12:41 PM
  3. Driver switching OFF
    By manofgresley in forum Artsoft Mach (3 & 4)
    Last Post: 06-06-2014, 04:57 PM
  4. FOR SALE: 24v 20 amp ABB switching power supply £90
    Last Post: 07-02-2014, 07:42 PM
  5. Home switching
    By Vard in forum General Electronics
    Last Post: 14-03-2012, 08:32 PM
