Thread: Foam milling
Threaded View
10-05-2019 #1
Given the same the same stepover and stepdown. Would it be preferable to use for instance an 8mm bullnose or a 4mm bullnose when cutting EPS foam. I believe the finish may be better with the larger dia. but would the smaller dia. be better for the grain structure?? I know not to climb cut but otherwise, not much experience of this material.
Any advise appreciated.
Milling Plastazote LD33 closed cell Foam - Any milling advice?
By Zeeflyboy in forum General DiscussionReplies: 17Last Post: 06-04-2022, 10:12 PM -
Foam for CNC machining
By Leadhead in forum General DiscussionReplies: 0Last Post: 10-05-2019, 11:00 AM -
Extra long end mills for milling foam
By gavztheouch in forum Marketplace DiscussionReplies: 6Last Post: 22-01-2014, 09:01 PM -
Machineable foam
By craigrobbo in forum Marketplace DiscussionReplies: 7Last Post: 03-02-2013, 08:40 PM -
CNC milling large foam bucks - DIY or supplier?
By cloudy in forum Marketplace DiscussionReplies: 0Last Post: 05-03-2012, 12:08 PM
