Page 1 of 4 123 ... LastLast
    Right then been a very very very quiet on the build front for a good while now for very good reason. To remedy this i thought i would kick off with what the immediate future plans are.
    I need to downsize my workshop a bit to move stuff out of the house to make way for our new arrival (no not the new mill?). To do this i took the decision to sell the Bridgeport as that take the most room up and if need be i have access to another. It really pains me as that is my favorite toy :cry:. Before i have had chance to list her i got the chance of an Arboga, great machine but does come with some challenges. It is in great shape and now in pieces on my workshop floor ready for when i can start.
    Bad points:
    1. 415v two speed motor - found nothing to say i can rewire for 240v, many have tried
    2. Spindle has an MT3 taper with a locking ring around the base as there is no way to put a draw bar because of the gearing above (my locking nut M62x1.5 is missing so will need to make a new one)
    3. The drill chuck is stuck in the taper (looks like it has never been removed since new)
    4. Table is not massive
    Good points:
    1. Very sturdy machine and knocks spots off most medium size mills, even modern ones
    2. Big enough for most things i play around with
    3. Everything is metric
    4. Takes up very little room
    5. 20" of gap between bed and spindle for those tall jobs
    6. Lots of space to hide anything and everything
    7. Quill has 140mm of movement which means i can run that as my Z and leave the column manual for different job sizes
    Plans:
    1. Strip it down
    2. Clean and repaint machine
    3. Make a new nut for the M62 thread (In case i need anything MT3)
    4. Make an ER32 collet holder to fit over the M62 thread instead of using the MT3 taper
    5. Pull the motor windings that are built into the machine and retrofit the guts from a 3phase 1HP 2800rpm doner. I will loose the two motor speeds but will get this back from the VFD control and will still have two mechanical speeds to play with.
    6. Use 20x5 ballscrews on the X and Y. Still not made my mind up about the Z?
    7. May need to make some new gears for the head but until i get it running will not know. The ones i may need to replace will be made out of tufnol. This will keep that head nice and quiet.
    So far:
    1. Purchased machine
    2. Ordered ballscrews
    3. Sourced new switches and things
    8. Have a 3phase motor (only 1400rpm) to test theory of swapping over gubbins.
    This is not going to be a quick project as my new son is due home next week after being born 9.5wks early. This has taken most of my time up as i have been left to look after the other kids and work full time. In the end i may loose my bridgeport which i still need to sell but will have a CNC mill.
    Lets see if i can be better at updating this log with more detail and pics than before :tup:
    Answers to plans.
    3/4: Don't bother, hit and miss whether you will get run out from just a thread and no register.
    Instead get a standard MT3 ER32 collet chuck and machine a groove in it with carbide tooling and fit a circlip to hold the washer and the M62 nut.
    BTW I have a short threaded test piece with the Arboga thread on it, OK if you want to borrow it or if you are dead stuck I can make you a threaded sleeve.
    5:You could always buy a 440 v 3 phase VFD feed it 440 v single phase from a yellow brick wired backwards and the earth centre tapping removed and use this as 440 v in but de-rated. You can pick 440v input vfd's quite cheap
    John S -
    Hi John
    I did look at the options for the motor similar to what you are saying but i like things to be neat and tidy. The casting on the head fits a standard frame so should not be an issue swapping the guts over from a doner motor. I may even find that i can pull some more wires out on the existing (split the coils) which only has 6 coming out? will get to that once i can pull it. As for the tooling like you say just mod standard arbors but will still have a go my way as it will make things nice and easy, with an er chuck and a facing mill should not need much else.
    Back to the motor if all else fails i already decided just to chop the lot off the top and fit a motor on top with a pulley going to the spindle. I can then fit a draw bar :naughty:
    John thanks for the offer of the test piece but i should be ok on that front.
    Look at bottom pic and you will see what i mean....http://www.lathes.co.uk/arboga/index.html
    Quote Originally Posted by 2e0poz View Post
    That doesn't sound good, especially if your chuck extractor isn't good and hard.
    Gi' it some wellie, hope they didn't use Loctite and if all else fails call out the fire brigade and see if they have something hydraulic :naughty:
    Should be fine robin as it has a knockout in the side of the quill.....but yes a bit of welly will work nicely
    I've promised myself some time next week so will start the clean up and get some pics up of how she looks now. Come up with very dark grey colour almost black and maybe a hint of green here and there? I know painting is not the be all and all but better to get that done whilst i have a chance or like everything else once it is together it will stay that way......I really do need to clean up the shop though and start getting rid of the rubbish...I hate cleaning.
    Still waiting on the screws to arrive for this one and still mulling ideas about the screw needed for the Z'd if i go down that route. Looking at it though i may be easier to replace the pinion gear that is there and work some way of tensioning it to alleviate the backlash?
    Did you get much further I am just going to start a similar conversion on my Arboga and would love to hear of your progress
    Geoff Cape Town
    Hi Geoff the short answer is yes and it is not the easiest conversion on the planet if you want to do it right. There is not a lot of space for 20mm ballscrews under that table. I've dumped the gearbox on top and going for two speed direct drive on VFD. Expect to do a lot of machining of the table. Not really a job unless you have access to another mill. I have had to build a complete new inner spindle to give tool release (it will accept R8 as well).
    The project has been on hold for a while due to other circumstances, i will get back to this thread properly as soon as i can.
    About time for an update and a drip feed of pics. Tonight I finished rebuilding the spindle for this machine in readiness for the Poly v pulleys i need to make. I dumped the original inner and used an old spindle from a lever lock collet closer. I re machined it to take new bearings and machined it to use R8 tooling (before you ask why?....i have loads of it already). I ended up with a 28mm id bearing on the top and needed a lock nut, apparently they don't do them? So i ordered a 28mm x 1.5 pitch hub nut for a citron/ Peugeot that fitted the bill and sunk a capcrew in the side and slit it. It locks lovely
    The next job is to make the pulleys and machine the rest of the spindle so it all looks good.
  1. CONVERSION: Harrison Mill Conversion
    By m_c in forum Conversion Build Logs
    Last Post: 27-10-2016, 07:15 PM
  2. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  3. NEW MEMBER: Saying hello, about to start a mill conversion.
    By irgonomics in forum New Member Introductions
    Last Post: 28-04-2013, 03:35 PM
  4. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
