Further to last: The Chinese servo controllers (only ones I know) have 5V optical-isolated inputs for the step/dir control, with separately excited inputs for the other discrete inputs (so you can use 12/24 for e-stops, etc). But, and this is the big but - the spindle speed inputs are 5V and can be directly coupled to a BoB output.
Edit: I liked the performance so much I replaced the phase/vfd on my ML7 lathe with a 2kW servo and drove that in exactly the same way.
25-04-2021 #2
Mine has a DB44 socket, I have a cable and a DB44 screw terminal block. I was hoping to avoid using an axis control for it.
It says that in speed mode it has a direction control on one of the DI ports, as in relay on is one direction, relay off is the other (apparently). Can drive this from pin 17. Then has the usual on/off which I have a seperate rocker switch for, + various others I'll likely not need in speed mode. Was hoping to use it this way, with the 0-10v servo input driven straight off the bob (board has it built in and I've tested it with a meter).
The outputs I'll just daisy chain to the estop via relays until I update my controller + boards. Then with more inputs I can go straight into the bobs optocouplers and ditch all the relays.
Sounds basically about right doesn't it?.
BUILD LOG: Sieg SX2.7 CNC conversion
By Edward in forum DIY Mill Build LogsReplies: 23Last Post: 11-06-2019, 03:01 PM -
Sieg X3 Conversion
By Vikash in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 04-01-2016, 05:18 PM -
CONVERSION: Need some help with a new SIEG SX2 Plus CNC Conversion
By Onocyclone in forum Conversion Build LogsReplies: 22Last Post: 17-09-2014, 01:00 PM -
Sieg sx2 conversion kit
By Goldigger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 24-04-2011, 07:42 PM -
FOR SALE: Sieg X2 Long bed + Milling vice -- SOLD--
By rnr107 in forum Items For SaleReplies: 0Last Post: 06-10-2010, 01:04 PM
