Ah, I should have been more clear - the inputs I'm using for speed control are as above. Of course it has the usual analogue inputs as well (from memory, at least!). What you've said makes perfect sense - and is a perfectly do-able solution. It sounds like you just need to export a direction (CW/CCW) the PWM output (0-10) and the servo-enable signal.
BUILD LOG: Sieg SX2.7 CNC conversion
By Edward in forum DIY Mill Build LogsReplies: 23Last Post: 11-06-2019, 03:01 PM -
Sieg X3 Conversion
By Vikash in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 04-01-2016, 05:18 PM -
CONVERSION: Need some help with a new SIEG SX2 Plus CNC Conversion
By Onocyclone in forum Conversion Build LogsReplies: 22Last Post: 17-09-2014, 01:00 PM -
Sieg sx2 conversion kit
By Goldigger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 24-04-2011, 07:42 PM -
FOR SALE: Sieg X2 Long bed + Milling vice -- SOLD--
By rnr107 in forum Items For SaleReplies: 0Last Post: 06-10-2010, 01:04 PM
