Thread: Am882 drives
    Found it thanks
    leadshine 2phase stepper driver AM882 AM882H DMA882S, input voltage :0VDC-100VDC/20VAC-80VAC both can work
    the latest version is DMA882S use for replace AM882 AM882H
    ​the different between am882 and AM882H is am882h with fan, am882 no fan
    1.Sensorless stall detection
    2.Extra-low motor noise offers excellent quietness
    3.Optimizes torque and nulls mid-range instability
    4.Self-test and Auto-configuration technology
    5.Options to set output current and microstep relolutions via DIP switch or software
    6.Microstep from 1 to 512
    7.Supply voltage up to +80 VDC
    8.Output current programmable, from 0.5A to 8.2A
    9.Automatic idle-current reduction and reduction rate is software configurable
    10.Fault out prevents damages to your machines or the materials
    Lives in East Lothian, United Kingdom. Last Activity: 8 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    IIRC AM882 are DC input only, whereas the H version will accept DC or AC input.
    Not sure about the DK bit.
    The DM-S drives are Leadshines latest drives, aimed to replace the old DM, AM, and EM drives, however they don't appear to have the same functionality as AM/EM drives as the only configuration is via DIP switches.
    And having just checked the leadshine website, I see they've just launched an EM-S drive, and all mention of DM-S has disappeared...
    I wonder if the DM-S didn't quite pass CE approval like the AM drives, so they've launched a new tweaked design for the EU/US?
  1. Vfd drives/dc motor drives question
    By Toolman321 in forum General Electronics
    Last Post: 23-05-2018, 06:31 PM
  2. EM806 vs AM882
    By Ger21 in forum Motor Drivers & Controllers
    Last Post: 27-02-2017, 09:57 PM
  3. I NeeD HeLp PLease AM882 a good choise
    By jpsicilia in forum Motor Drivers & Controllers
    Last Post: 16-08-2014, 10:27 PM
  4. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  5. Problem with AM882 drivers !..... or it could just be me !
    By Buba b in forum Motor Drivers & Controllers
    Last Post: 03-04-2013, 09:28 AM
