    Hi all
    Just wanted to introduce myself. My name is Rob I'm from North Wales and I have decided to jump feet first into the world of CNC. I have purchased one of the 3018 Pro Chinese machines and so far it seems very capable. I am wanting to get into aluminium pet tag engraving which mainly uses anodised aluminium. So far I've had mixed success but need a bit of help going forward I think. Anyway, it'll be nice to get to know you all and hopefully in the process help each other out.
    Rob
    Hi Rob, welcome to the forum!
    I saw a good video recently where a guy was using a spring loaded bit to drag engrave aluminium Dog tags. What type of engraving do you intend using?
    Well so far I just have v tip engraving bits. I am trying to find the correct feeds and speeds that doesn't break the tip.
    Quote Originally Posted by visedge View Post
    +1 for this - I did make a similar device and it was as good if not better than my attempts with a V-bit. Part of my problem was, I think, a random bunch of anodised aluminium sheet (offcuts from eBay) which was gummier than a fruit pastille - cut poorly and suffered a lot of tearing when engraved. The spring-loaded drag bit resolves a number of issues including the gumminess and flatness.
    From my experience - probably worth sourcing/buying a proper drag engraver.
    Don't kid yourself with your machine - try to get a good understanding about any backlash that you have, and the rigidity of the frame - no point looking for precision engraving if the machine is distorting under lateral loading. Also examine and understand the stiffness of your spindle mount.
    Clive S's Avatar
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Yes, three series is very gummy try 6 series or even 7 series
    I bought one of these drag engravers a while back. Haven't used it much as yet but the tests I did looked good whereas the 22 degree PCB engraving bit I tried just made a mess. The spring loaded engraver is also much more tolerant of uneven surfaces.
    https://www.engravingbit.com/Drag%20...ng%20tool.html
    Kit
  1. NEW MEMBER: good evening gents
    By fastcarl in forum New Member Introductions
    Last Post: 01-06-2010, 10:07 PM
  2. NEW MEMBER: Good evening all.
    By monza in forum New Member Introductions
    Last Post: 28-12-2009, 08:53 PM
  3. NEW MEMBER: Good evening.
    By itbookham in forum New Member Introductions
    Last Post: 18-11-2009, 08:46 PM
  4. NEW MEMBER: north wales
    By eddythefly in forum New Member Introductions
    Last Post: 23-01-2009, 12:44 PM
