    i have always wanted to learn how to use a lathe. I studied electronic engineering but through life's many turns have found myself working as a technical writer in central Italy for a manufacturing company. I have been very impressed by Italian engineering and I wish they had the same high levels when it comes to service. I have recently learnt to weld but seeing the engineers in the shop has spurred me on to get a lathe
    Through research I have found this site and a member has helped me narrow down my choice. I look forward to learning from all of you in the very near future
    RobC's Avatar
    Lives in Leeds, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 8-9 years. Has a total post count of 118. Received thanks 16 times, giving thanks to others 21 times.
    Rule number one with a lathe. Keep the chuck key out of the chuck when not in use! Rule number two is don't wear long sleeves or articles that can be wrapped around the work! Following those you should have no problem learning, welcome!
  4. The Following User Says Thank You to RobC For This Useful Post:
  5. #4
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Quote Originally Posted by RobC View Post
    As an apprentice and a 12 week machinist appreciation stint (I was a spark) for an engineering firm - remove all rings. And check the chuck is secure.
    Of course, advice is one thing...
  6. #5
    Hi Steven,
    The other bit of advice is to rotate the chuck at least 1 rotation by hand before starting. 99.9% of the time it will be fine, but it is always possible that the chuck jaws can hit the cross slide, especially when holding larger parts (they protrude further from the chuck).
    The WM250V model I have also has a powered cross slide. After using the lathe for many years I think it is not a vital feature, and face machining by hand is usually fine.
    If you want to see mine in action have a look on my channel here as an example (skip past the rambling if you like to 10:27).
    https://www.youtube.com/watch?v=RRcvbDO1FgE
    And here in the CNC build at 08:30
    https://www.youtube.com/watch?v=tijVFCKuLPc
  1. CNC style lathe home brew Lathe for drilling and cutting.
    By Bodge in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-04-2012, 10:45 AM
