+1 for this - I did make a similar device and it was as good if not better than my attempts with a V-bit. Part of my problem was, I think, a random bunch of anodised aluminium sheet (offcuts from eBay) which was gummier than a fruit pastille - cut poorly and suffered a lot of tearing when engraved. The spring-loaded drag bit resolves a number of issues including the gumminess and flatness.
From my experience - probably worth sourcing/buying a proper drag engraver.
Don't kid yourself with your machine - try to get a good understanding about any backlash that you have, and the rigidity of the frame - no point looking for precision engraving if the machine is distorting under lateral loading. Also examine and understand the stiffness of your spindle mount.Last edited by Doddy; 20-05-2019 at 07:47 AM.
20-05-2019 #2
Yes, three series is very gummy try 6 series or even 7 series
20-05-2019 #3
I bought one of these drag engravers a while back. Haven't used it much as yet but the tests I did looked good whereas the 22 degree PCB engraving bit I tried just made a mess. The spring loaded engraver is also much more tolerant of uneven surfaces.
https://www.engravingbit.com/Drag%20...ng%20tool.html
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
NEW MEMBER: good evening gents
By fastcarl in forum New Member IntroductionsReplies: 2Last Post: 01-06-2010, 10:07 PM -
NEW MEMBER: Good evening all.
By monza in forum New Member IntroductionsReplies: 2Last Post: 28-12-2009, 08:53 PM -
NEW MEMBER: Good evening.
By itbookham in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 08:46 PM -
NEW MEMBER: north wales
By eddythefly in forum New Member IntroductionsReplies: 1Last Post: 23-01-2009, 12:44 PM
