  1. #4
    It looks like the driver is one of the many TB6560 based drivers
    some CNC kits sold comprise of motors & drivers and a 36V power supply
    the TB6560 IC has a maximum supply limit of 24V !!!! so the drivers don't last very long
    most if not all TB6560 drivers do have design problems
    https://www.cnczone.com/forums/gener...-software.html
    with the 24V supply they should be OK but the low supply voltage limits the speed you can step the motor
    do you have a multimeter to do some simple continuity checks ?
Name:	driver terminals.jpg
    the main thing is to connect one motor coil across the +A & -A terminals
    and the other across the +B & -B terminals
    you can sort out the motors direction later in software
    John
    PS
    your driver looks like another version of the TX14207
    PPS
    going by this diagram it looks like the + step , + direction & + enable terminals are commoned and only have one + 5V connection to the breakout board +5V
Name:	6040 TX14207 TB6560 stepper driver wiring.jpg
  1. On going chinese 6040 problems
    By amxen in forum Chinese Machines
    Last Post: 03-06-2020, 08:46 AM
  2. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  3. More Problems with Chinese 6040
    By Rye in forum Chinese Machines
    Last Post: 07-12-2017, 01:13 AM
  4. Machine better than a chinese 6040 for a beginner?
    By d4cnc in forum Gantry/Router Machines & Building
    Last Post: 09-11-2015, 12:47 PM
  5. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
