    yes i set the switches to 8 but i will check the travel distance before i do a test cut.
    i will get back to you and let you know how i get on
    i have just gone to set the job up and zeroed everything and noticed the stepper motor is creeping while on standby. i run the cutting program anyway just to see how it performed and when cutting in slow areas like arcs or corners the motor is noisy as if missing steps
    Quote Originally Posted by Jed Clampit View Post
    I would check thee stepper motor connections at the bob to see if they are loose it could also be EMI does it move when the spindle is off. Which stepper is it all or just one?
    it is only on the axis that the new board operates and it only seems to do it when the spindle is running
    Then that sounds like EMI
    what is EMI Clive ?
    EMI is Electromagnetic interference
    Is it just the new axis driver that's moving on its own ?
    does your break out board look like this TX14175
Name:	TX14175 circuit and board.jpg
    John
    Clive is spot on here.
    The EMI often tracks up the mains lead from the spindle motor/driver and back down the lead to the PSU for the control system, separating the two to plug-in points opposite ends of the ring main can help, or running the spindle motor/driver from the furthest possible socket via an extension lead.
    Ideally you'd fit separate EMI filters to the mains inputs close to the equipment.
    thanks for the replies. i did a quick search and found these
    https://www.cnc4you.co.uk/Electrical...FI-Suppression
  1. On going chinese 6040 problems
    By amxen in forum Chinese Machines
    Last Post: 03-06-2020, 08:46 AM
  2. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  3. More Problems with Chinese 6040
    By Rye in forum Chinese Machines
    Last Post: 07-12-2017, 01:13 AM
  4. Machine better than a chinese 6040 for a beginner?
    By d4cnc in forum Gantry/Router Machines & Building
    Last Post: 09-11-2015, 12:47 PM
  5. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
