Thread: UC400ETH connection to PC/Laptop
23-05-2019 #1
Hi I had a dell desktop pc with XP running that had been set up with Mach3 and the UC400 adapter which all worked fine, I then benched my cnc 6040 for a year due to health issues and recently came back to it all to find my desktop pc had a hard drive failure and cpu fan failure.
had a spare laptop with Windows Vista Home Edition and so plugged my ethernet cable into their instead (disabled the power down options for the laptop) but discovered that I am now getting "local or limited connection to unidentified connection"
I cannot figure out how to get the UC400 and laptop to see each other (also plugged into my windows 10 pc both had the adapters for the relevant windows) same result.
I have swapped out the cable,
reset the UC400,
checked the IP address which is set to automatic,
Is there something I'm missing? PS as been out of the loop for a good year I am re learning everything from scratch as forgetting most of the technical setup side.
24-05-2019 #2
See page 9 of the UC400 manual. Set the IP address to 10.10.10.10, not automatic.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Dreaded X axis stepper error using UC400ETH and UCCNC !!!
By dachopper in forum CNCdrive (UC100, UC300ETH)Replies: 64Last Post: 29-01-2021, 03:27 PM -
Which Connection ?
By manofgresley in forum Stepper & Servo MotorsReplies: 17Last Post: 13-07-2020, 01:55 PM -
Laptop for CNC Controll
By Tenson in forum Laptops & TabletsReplies: 9Last Post: 15-11-2018, 08:51 PM -
Mach 3 using laptop and usb
By drftnr34 in forum Motor Drivers & ControllersReplies: 6Last Post: 09-07-2015, 04:38 PM -
Mach3 on Laptop
By Lovre in forum Artsoft Mach (3 & 4)Replies: 13Last Post: 02-01-2013, 05:13 PM
