    Hi Guys,
    I need some help setting up the spindle relay on the software as i cannot get the relay working
    Thanks,
    Mykles
    SOLVED LOCKED.
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    You might find a constructive response if you provide a bit more info.
    Peering into my crystal ball, I'd ask where the relay is (BOB?), whether you've got an output under Mach3 assigned to the corresponding pin on the BOB and then whether you'd transferred the output number into the Spindle control page on Mach3. Damned crystal ball is all foggy.
  3. The Following User Says Thank You to Doddy For This Useful Post:
    Thanks i have worked it out!
  5. #4
    In the spirit of this forum, it would be nice to know what the problem was and how you solved it! Just to help others (that's what we are here for).
  6. The Following User Says Thank You to cropwell For This Useful Post:
  1. Connect spindle to mach
    By Duffman in forum Gantry/Router Machines & Building
    Last Post: 14-07-2020, 06:08 AM
  2. Mach 3 control panel help
    By IanParkin in forum Artsoft Mach (3 & 4)
    Last Post: 05-09-2014, 04:05 PM
  3. Mach lathe spindle speed control
    By GeoffV in forum Artsoft Mach (3 & 4)
    Last Post: 21-05-2014, 08:34 AM
  4. Mach 3 control of DC Brushless motor?
    By templecorran in forum Artsoft Mach (3 & 4)
    Last Post: 18-11-2010, 04:20 PM
