    Hi Guys,
    Is it a way that i can use a parallel port to Ethernet adaptor to connect my mach 3 board to my laptop with the Ethernet port.
    Thanks,
    Myles
    https://www.amazon.co.uk/Ethernet-Co.../dp/B07KWBFPXW (found with google, in seconds)
    BTW Mach3 with 64bit Win10 - does it work ? I have a feeling the answer is NO!
    Just a slight cautionary note - as I have the 5-axis version of the above controller. Note, it's a 200kHz controller - the effect of this is the output pulses are active for 2.5us (I measured) and this can cause problems with cheaper stepper drivers (in my case, the opto-isolator response rate). The rather limited driver doesn't provide any mechanism to change the pulse width and doesn't honour the Mach3 settings. So, if you have one of these controllers, and you lose steps (in my case it was visually evident in operation) then look at the stepper driver response rate. DO NOT google for a pulse-extender, at least not on your company's IT system(!) Been there...
    Didn't Mach3 get updated for Win10/64 bit? Either way, Win10 and auto-updates pee me off enough to stick with 7 for my controlling PC (running UCCNC/SX2.7, I still have XP on my Mach3/StarMill PC).
    Quote Originally Posted by myles.merry View Post
    Hi Guys,
    Thanks,
    Myles
    Only if the driver gives Mach3 direct access to pin status control, it is not driven as a Parallel Port, doing so does not give motion control.
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Most Leadshine drives require 5uS pulses. Not sure about the latest ones, but certainly the EM and standard ones did.
    Mach3 will run on pretty much any modern version of windows, it's the parallel port driver that won't work on anything 64bit, or anything newer than Win7 (Win7 32bit is the last version the PP driver will work on). The reason is Microsoft switched to an encrypted kernel at that point, and as the PP driver relies on controlling the kernel, it wouldn't work without a lot of hacking. IIRC Art did manage to do some basic testing, but discovered the encryption regularly changes, so it just wasn't feasible.
    Personally, if all you need is a single parallel port interface, I'd go for a UC100. It's not ethernet, but it's probably the simplest option with good support.
  1. running mach 3 with a usb to parallel adapter
    By Kendrick57 in forum Artsoft Mach (3 & 4)
    Last Post: 06-01-2020, 04:49 PM
  2. windows 10 64bit and breakout board
    By terry1956 in forum Computer Software
    Last Post: 23-01-2017, 02:14 PM
  3. CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
    By Greeny in forum Control Hardware & Systems
    Last Post: 14-11-2013, 11:59 PM
  4. problems with mach or windows
    By johngoodrich in forum Computer Software
    Last Post: 02-03-2012, 07:23 PM
  5. Mach 2 / 3 - Windows 2000/XP
    By teetat in forum Artsoft Mach (3 & 4)
    Last Post: 10-07-2009, 02:47 PM
