What's the drives max speed, and analogue input scaling set to?
I'd guess most drives will default to 3000rpm, and 3000rpm at 10v.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
27-05-2019 #2
Exactly that - 3000rpm, 10v.
300rpm/v
27-05-2019 #3
27-05-2019 #4
Tried that now, apart from altering either the top speed or the acceleration ramp depending on which way i tweaked the ramp, it made no difference at all - still get the increasing error count above 2990 rpm
27-05-2019 #5
Ok,
Using my bench PSU it was giving 2965rpm one way and 2971rpm the other.
It was also creeping with the inputs shorted out.
I ran the auto zero speed set function which killed most of the creep.
Then adjusted the gain to 305rpm/V
It now gives 3000rpm forwards and backwards.
Did it fix the issue?
No :(
A short video of the Pid screen at 2990rpm and 3000rpm
https://youtu.be/i7GEe7jAoY4
27-05-2019 #6
Motor slip ;-)
Most servo spindle controllers have a switch-over speed from Positional to Speed between 2000rpm & 3000rpmYou think that's too expensive? You're not a Model Engineer are you? :D
27-05-2019 #7
But what can i do about it?
Adding 4th axis to stig x2
By terry1956 in forum General DiscussionReplies: 1Last Post: 24-08-2018, 01:57 PM -
adding high speed spindle
By jerome in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 21-12-2017, 08:19 PM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
Adding earth cable to 2.2Kw Chinese Spindle
By Dwayne Dibbley in forum Generic Chinese SpindlesReplies: 4Last Post: 13-03-2013, 04:04 PM -
SolidCAM/WRKS troubles
By 25ncjimmy in forum SolidworksReplies: 4Last Post: 11-03-2011, 05:45 PM
