08-06-2019 #19
Tech:
Yes, no.
Steppers are not much different from servos.
The servos step up the "next" step magnetically before the rotor is there.
They anticipate the position of the rotor and tightly couple it to the angle of the rotor via the encoder.
And using the skewed rotors (afaik) +magnets they can keep this up indefinitely.
And can use very heavy currents temporarily, since the duration is so short.
Servos used to run 12 kHz, 0.1 ms each.
But servos have better magic steel and magic wire.
Very complex thing with magnetic flux rise time, decay time, heat losses, efficiency, mag. flux strength, inductance, reluctance, etc.
The servos have probably 1% difference in materials but might have 100x difference in terms of magnetic inductance/reluctance effects at very high speeds == 500 kHz - 4 Mhz of modern ac servos.
Dip Switch settings on the M542 stepper motor drivers
By manofgresley in forum Motor Drivers & ControllersReplies: 13Last Post: 04-01-2021, 09:10 PM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM -
Stepper motor coil resistance. What is an acceptable value?
By gavztheouch in forum Stepper & Servo MotorsReplies: 3Last Post: 30-11-2012, 05:53 PM -
Setting up stepper motor drivers
By croy in forum Motor Drivers & ControllersReplies: 25Last Post: 30-09-2012, 09:51 PM -
eBay Stepper Motor Drivers from China
By Mad Professor in forum General ElectronicsReplies: 6Last Post: 20-07-2009, 10:54 PM
