Thread: Steel x axis idea
No increase in strength or rigidity for the introduction of distortion in cutting and welding in the insert? Why?
Start with a smaller box and weld on additional box sections to build your cross section, that will at least add some strength and rigidity with less chance of unacceptable distortion.You think that's too expensive? You're not a Model Engineer are you? :D
02-06-2019 #2
The other way to do that is start with the box section then weld 2 thick bars onto the front face, one at the top and one at the bottom. Leave enough gap in the middle to clear the ballnut. Rails can mount to these bars and you have plenty of depth for the threads. Similar outer profile to your drawing but without the discontinuities.
Added steel channel to X-axis c-beam
By wiremonkey in forum Gantry/Router Machines & BuildingReplies: 23Last Post: 16-07-2018, 04:02 PM -
BUILD LOG: Desktop size steel welded router 3 axis
By Tom J in forum DIY Router Build LogsReplies: 84Last Post: 28-03-2017, 09:36 PM -
BUILD LOG: New build - Steel - 3 Axis initially then conversion to 4 axis.
By Slixxor in forum DIY Router Build LogsReplies: 44Last Post: 29-12-2016, 02:57 AM -
Construction Idea Discussion: Large Steel tubes + non shrink grout = win?
By Noplace in forum Machine DiscussionReplies: 1Last Post: 31-05-2016, 12:37 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM
