    I want to cnc a scaloped guitar fretboard, similar to the pics.
    I can draw what I need in my ancient Acad but not generate a model or an stl file.
    I wondered if anyone would be willing to generate a model and a file
ID:	25840   Click image for larger version.
ID:	25841   Click image for larger version.
ID:	25842   Click image for larger version.
    Attached Files Attached Files
    Try this, Yngwie
    Edit: this file was incorrect, the correct ones are attached to a more recent post below
  3. The Following User Says Thank You to EddyCurrent For This Useful Post:
    Many thanks, opens perfectly in Estlcam
    Yngwie ? I wish, don't have a musical bone in my body, but do enjoy listening and watching him.
    I belong to a men's shed and run a cnc router I built for them, there are several guitar makers there and they keep discovering the joys of CNCing
  5. #4
    Hi John,
    Here's a guitar maker and player from Barrow-on-Soar who makes excellent guitars (without CNC) https://www.youtube.com/watch?v=gLzPD1ZQca0
    Cheers,
    Rob
  6. #5
    30 years ago, I built a guitar with a scalloped freetboard. I did it with files and sandpaper. :)
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  7. #6
    Hi Eddy
    Sorry to impose on your good nature, if possible could you do the same to these files, it has a different neck radius.
    Funny lot these guitar makers
    Hi Rob, won't open in my firefox browser
  8. #7
    I bet you used to cut up your plywood sheets with a handsaw
    John
  9. #8
    John,
    It's a good job you came back with more files because it made me realise I did not put a radius on the first stl model.
    I will do them now.
    Just to check, looking at the drawings (properly this time) the fretboards appear to have a compound radius, i.e. a different radius at the nut than at the last fret, is that correct ?
  10. #9
    Hi Eddy
    Yes they do have a compound radius, and each guitar maker seems to have his own preferences, had not noticed the lack of radii since only looked at them in Esltcam
    John
  11. #10
    Sorry about the oversight earlier, these two files are correct and as per drawings.
    Images show the stl files opened in CamBam
    In the CAD (Rhino6) I used a "Two Rail Sweep" with the end profiles being the two rails and the scalloped profile being the cross section.
ID:	25857   Click image for larger version.
  12. The Following User Says Thank You to EddyCurrent For This Useful Post:
  1. Converting .eps file for cam use
    By Leadhead in forum General Computing
    Last Post: 30-06-2017, 08:38 PM
  2. .GD4 file extension ?
    By greenz123 in forum CAD & CAM Software
    Last Post: 30-06-2015, 12:44 PM
  3. how do you convert a .png to a .tap file?
    By valeria caltabiano in forum General Computing
    Last Post: 16-02-2015, 01:25 PM
  4. File upload problems - attachments file extension support !
    By Swarfing in forum General Discussion
    Last Post: 08-03-2013, 02:37 PM
