    Hi John,
    Here's a guitar maker and player from Barrow-on-Soar who makes excellent guitars (without CNC) https://www.youtube.com/watch?v=gLzPD1ZQca0
    Cheers,
    Rob
    30 years ago, I built a guitar with a scalloped freetboard. I did it with files and sandpaper. :)
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    I bet you used to cut up your plywood sheets with a handsaw
    John
    John,
    It's a good job you came back with more files because it made me realise I did not put a radius on the first stl model.
    I will do them now.
    Just to check, looking at the drawings (properly this time) the fretboards appear to have a compound radius, i.e. a different radius at the nut than at the last fret, is that correct ?
    Hi Eddy
    Yes they do have a compound radius, and each guitar maker seems to have his own preferences, had not noticed the lack of radii since only looked at them in Esltcam
    John
    Sorry about the oversight earlier, these two files are correct and as per drawings.
    Images show the stl files opened in CamBam
    In the CAD (Rhino6) I used a "Two Rail Sweep" with the end profiles being the two rails and the scalloped profile being the cross section.
ID:	25857   Click image for larger version.
    Attached Files Attached Files
  7. The Following User Says Thank You to EddyCurrent For This Useful Post:
  8. #7
    Hi Eddy
    Thanks once again, I consider that a fortunate escape for me, they get a bit precious over their bits of wood
    I bet one of them will want a flat one anyway
    John
  9. #8
    Hi Eddy
    Sorry to impose on your good nature, if possible could you do the same to these files, it has a different neck radius.
    Funny lot these guitar makers
    Hi Rob, won't open in my firefox browser
  1. Converting .eps file for cam use
    By Leadhead in forum General Computing
    Last Post: 30-06-2017, 08:38 PM
  2. .GD4 file extension ?
    By greenz123 in forum CAD & CAM Software
    Last Post: 30-06-2015, 12:44 PM
  3. how do you convert a .png to a .tap file?
    By valeria caltabiano in forum General Computing
    Last Post: 16-02-2015, 01:25 PM
  4. File upload problems - attachments file extension support !
    By Swarfing in forum General Discussion
    Last Post: 08-03-2013, 02:37 PM
