  1. #9
    Sorry about the oversight earlier, these two files are correct and as per drawings.
    Images show the stl files opened in CamBam
    In the CAD (Rhino6) I used a "Two Rail Sweep" with the end profiles being the two rails and the scalloped profile being the cross section.
ID:	25857   Click image for larger version.
    Attached Files Attached Files
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  1. Converting .eps file for cam use
    By Leadhead in forum General Computing
    Last Post: 30-06-2017, 08:38 PM
  2. .GD4 file extension ?
    By greenz123 in forum CAD & CAM Software
    Last Post: 30-06-2015, 12:44 PM
  3. how do you convert a .png to a .tap file?
    By valeria caltabiano in forum General Computing
    Last Post: 16-02-2015, 01:25 PM
  4. File upload problems - attachments file extension support !
    By Swarfing in forum General Discussion
    Last Post: 08-03-2013, 02:37 PM
