    Evening, people.
    Are there good sources for laserable thin (1.5-5mm) plywood in UK that deliver to Northern Ireland ? Looking them cut to A1 sized pieces before shipping.
    Also, i cant seem to find anywhere that sells proper wood veneer in sheets (same A1ish size), only find pvc nasiness.
    Ebay is useless, either small pieces, unknown quality or way overpriced.
    Help...
    not sure about the plywood but try here for veneer
    https://www.thewoodveneerhub.co.uk/
    For thin birch ply I have found James Latham to be very good.Not sure if they supply to Northern Ireland though.
    RobC's Avatar
    Lives in Leeds, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 8-9 years. Has a total post count of 118. Received thanks 16 times, giving thanks to others 21 times.
    Im sure you got that plywood sorted if not I would recommend reclaimed wood from www.audriniliving.com
  1. Baltic Birch Plywood availability in the UK
    By Ccrewz in forum Marketplace Discussion
    Last Post: 08-09-2019, 10:18 PM
  2. Where to buy plywood veneer in UK?
    By carol in forum Woodwork Discussion
    Last Post: 14-09-2017, 08:34 PM
  3. RFQ: RFQ - 2 Off Birch Plywood Profiles (overall size 269mm OD)
    By pvuk5 in forum Projects, Jobs & Requests
    Last Post: 13-10-2014, 10:12 AM
  4. Glue for Vacuum Press Veneer?
    By Tenson in forum Woodwork Discussion
    Last Post: 05-09-2014, 03:42 PM
  5. Is birch ply my best option?
    By mark84 in forum Wood Finishing Tips & Tricks
    Last Post: 15-01-2014, 06:13 PM
