    Wal's Avatar
    Hello all.
    This started as a woodworking project before the decision was made that making these in wood was going to be a nightmare - both in terms of finding dark exotic stock in the sizes and quantities that were needed, the ethical aspect of using all that stock and the expense and the wastage (both in time and material) that any tear-out around the details would lead to. In addition to all that, the aesthetics of the overall design asked for something a bit different too.
    Eventually the design team settled for Corian - oh yes, still expensive but a lot more stable and predictable to work with.
    Anyway, I present to you the new cocktail coasters for the American Bar at the Savoy Hotel in London. Yes, that one..!
Name:	2019-03-09 18.03.17.jpg
ID:	25878 Click image for larger version.
ID:	25879 Click image for larger version.
ID:	25880 Click image for larger version.
ID:	25881 Click image for larger version.
    This was a real mission of a project. Each coaster is engraved (using 0.6 and 0.4mm cutters) and resin filled. The top faces along with machined edges and transitions into the round-overs all needed to be hand finished through multiple grades of wet and dry before getting rubbed down with Scotchbrite and finally polished. No micro-scratches allowed. I had 125 to make. Days and days of sanding/polishing - my arm barely worked by the end of it..!
    A really nice project to be a part of - must pop down for a drink one of these days..!
    Wal.
  2. The Following 3 Users Say Thank You to Wal For This Useful Post:
  3. #2
    Lovely work!
    I don't suppose you were allowed to put a maker's name on the back?
    Wal's Avatar
    I think something small and tasteful would have been permitted - although it would more than likely have been the design agency that got first dibs on that..!
    Wal.
  5. #4
    Nice work Wal.
    Rob-T
  6. #5
    Cracking job Wal
  7. #6
    Very nice indeed, what did you use to put the radius around the top edge ?
  8. #7
    Wal's Avatar
    Thanks guys.
    Eddy, I used a 3mm radius one of these:
    https://www.shop-apt.co.uk/corner-ro...ide-45hrc.html
    - you can see it in action here:
    https://www.instagram.com/p/Bv-Zbb4n..._web_copy_link
    They're really useful tools - I use mine a fair bit. You program it as a 1.5mm tool (tip diameter), touch off the tip and plunge it to a depth of 3mm - in reality you might want to leave it just shy of 3mm, too deep is less forgiving than a tiny bit too shallow...
    Wal.
  9. The Following User Says Thank You to Wal For This Useful Post:
  10. #8
    Hats off to you Wal, those look fantastic, very nice
    I've often thought about getting some corian, but could never find any offcuts and a full sheet would just be too expensive for playing around with.
  11. #9
    Wal's Avatar
    Yeah - a full sheet set me back £780..!
    I imagine I could have got it cheaper directly from the manufacturer, but they won't sell it to you unless you're an approved fabricator - ie. taken their instructional course in how to use it (cut, glue etc.)
    You just need to get lucky in terms of finding off-cuts. A lot of what's out there has metallic flecks etc, so might not be suitable for the intended purpose.
    Wal.
  1. Bespoke CNC
    By Prop Man in forum General Discussion
    Last Post: 13-12-2010, 05:17 PM
