    Hey guys,
    can anyone help in letting me know which software would be best suited to cutting the attached part. ive tred Cut3D (May be doing it wrong) but i just cant seem to figure it out. been away from the machine for a while doing this sort of stuff
    Basically its a 200mm dia circle but i need to mill away the top to get the 1050mm radus cutting the rest is fine
Name:	1050 Dia Hatch.PDF
    My idea would be to make a 3D model of it then import it as an stl file. CamBam for example could easily cut it in that manner or any other software that can make a 3D toolpath from an stl model.
    The bolt holes and central cutout would be standard 2D operations
    If it's any help I've attached an stl model, 200mm dia. with a 1050mm radius top and 20mm sides at the highest.
    Attached Files Attached Files
    I haven't used cut3D ,but I would imagine that since the latest release of Vcarve pro will generate toolpaths for 3D objects from an .stl file you ought to be able to find a way.Have you looked at the Vectric tutorials on youtube?They might just jog the memory If you have done this sort of thing before.
    Cheers lads, this are now coming back to me on the 3D side after seeing your files. also thanks to the PM's helping also its very much appreciated!
    I whats having a play with Fusion360 and this also seems promising but thats a whole new learning curve
    Wal's Avatar
    Stick with it, once the penny drops it's well worth it..!
    Yeah it seems good. Only thing I can’t figure out is once the centre is cut out to just kill the face of the circle rather than a 200mm square. Looking at getting the machining time down
  1. Name the vfd part?
    By charlieuk in forum General Electronics
    Last Post: 17-01-2018, 07:05 PM
  2. WANTED: part number
    By tinshak in forum Items Wanted
    Last Post: 10-02-2015, 10:10 PM
  3. RFQ: Need part
    By Buckis in forum Projects, Jobs & Requests
    Last Post: 21-02-2014, 01:21 AM
  4. Replies: 2
  5. What I did this weekend.. part 2
    By irving2008 in forum Metalwork Discussion
    Last Post: 08-04-2012, 02:57 PM
