    >I whats having a play with Fusion360 and this also seems promising but thats a whole new learning curve
    Stick with it, once the penny drops it's well worth it..!
    Yeah it seems good. Only thing I can’t figure out is once the centre is cut out to just kill the face of the circle rather than a 200mm square. Looking at getting the machining time down
    In CamBam for example you would set up two boundary lines, one for the outer diameter and one for the inner. Next, convert the space between those boundary lines to a "Region", the 3D machining operation would then restrict itself to the defined Region.
  3. The Following User Says Thank You to EddyCurrent For This Useful Post:
    Wal's Avatar
    Similarly, in F360, depending on what tool strategy you have chosen, there is often a way of telling the program which surfaces you want to cut or avoid. Check out the pics below. It's as easy as ticking the touch/avoid checkbox and selecting a face. Very neat.
ID:	25894 Click image for larger version.
    Wal.
  5. #4
    Cut 3d can product the g code for this part. Test the g code in an edit program before wasting material.
  6. #5
    Wal's Avatar
    It can indeed, but it's pretty inefficient in how it lets you choose which bits to cut (it doesn't) and how it calculates the paths. It basically does everything in one go, well, two - a rough and and a final. The biggest issue is that steep walled models such as this will be pretty gouged around those top edges...
    I like Cut 3D / VCarve - Cut 3D works really well with organic models, but for something like this I'd go with F360 every time. The control you get makes you question how you ever did without..!
    Wal.
  1. Name the vfd part?
    By charlieuk in forum General Electronics
    Last Post: 17-01-2018, 07:05 PM
  2. WANTED: part number
    By tinshak in forum Items Wanted
    Last Post: 10-02-2015, 10:10 PM
  3. RFQ: Need part
    By Buckis in forum Projects, Jobs & Requests
    Last Post: 21-02-2014, 01:21 AM
  4. Replies: 2
  5. What I did this weekend.. part 2
    By irving2008 in forum Metalwork Discussion
    Last Post: 08-04-2012, 02:57 PM
