    First of all let me tell you that I am using a very un-sophisticated manually operated duplicating router, using at first, a Huanyang VFD / 1.5kw aircold spindle combination. After a year of service, which by the way was not continuous, the VFD started faulting with several different overload faults. I ended up purchasing two XSY-AT1 VFDs and a spare motor on Ebay. I completely rewired the machine then started on the long journey of programming the VFD. After taking everyone’s advise on different parameters, which got me really close, I finally tweaked the settings where the spindle spins and stops correctly using the onboard commands. If anyone needs them, here are my final parameters. Don’t ask me my logic, because it was all trial and error......mostly error.
  2. The Following User Says Thank You to tarawa For This Useful Post:
  1. HELP! Colchester CNC 350 + Fanuc Series O-T Parameters - Diagnostics
    By Constantin in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 26-08-2019, 05:38 AM
  2. Replies: 14
    Last Post: 19-10-2017, 02:34 PM
  3. 3020 / 3040 / generic chinese router accuracy
    By m_c in forum Machine Discussion
    Last Post: 24-07-2014, 11:54 PM
  4. Optimize parameters for mills with tips
    By hoezap in forum Tool & Tooling Technology
    Last Post: 15-06-2013, 01:18 PM
  5. G4 Dwell parameters
    By mmcp42 in forum Programmers Corner
    Last Post: 31-12-2010, 04:49 PM
