17-01-2021 #24
It is wired as delta, what do you mean with wired correctly at the motor end? V is V, W is W, U is U.
Yes its a 2 pole motor. I checked all connections several times and do also a trough check with multimeter.
Max current is set to 8000.
I saw in different videos nobody needs torque compensation for starting motor with load.
It seams that one phase has not enough power and causes the motor stuttering under load. So I think something is wrong with my Vfd.
HELP! Colchester CNC 350 + Fanuc Series O-T Parameters - Diagnostics
By Constantin in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 26-08-2019, 05:38 AM -
Generic Chinese VFD, no CE and no earth connection to exposed metal heatsink
By Jeff in forum Generic Chinese SpindlesReplies: 14Last Post: 19-10-2017, 02:34 PM -
3020 / 3040 / generic chinese router accuracy
By m_c in forum Machine DiscussionReplies: 2Last Post: 24-07-2014, 11:54 PM -
Optimize parameters for mills with tips
By hoezap in forum Tool & Tooling TechnologyReplies: 0Last Post: 15-06-2013, 01:18 PM -
G4 Dwell parameters
By mmcp42 in forum Programmers CornerReplies: 10Last Post: 31-12-2010, 04:49 PM
