17-06-2019 #2
Wanted to add, the motor is 8 wired, wired in Bi Polar parallel.
This is the motor.
https://www.cnc4you.co.uk/Stepper-Mo...?search=nema34
The specsheet here - https://cnc4you.co.uk/resources/Step...1%2012.5Nm.pdf
Based on my current gearing the motor runs around 1600 RPM to achieve 4000 mm/min (I need to double check the gearing). Does anyone know what max RPM could be, nothing declared on the motor. I can email and ask the supplier but if I gear down some more, whilst 4000 mm/min is less important than stability, its nice to have high rapid rate on a large machine.
How to properly run in spindle bearings.
By driftspin in forum Generic Chinese SpindlesReplies: 8Last Post: 22-11-2018, 04:11 PM -
Pokeys57U / Leadshine EM806 / Mach 3 - Confusion
By Chaz in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 29-09-2017, 04:03 PM -
How properly to install the rack
By masinecc in forum Rack & Pinion SystemsReplies: 6Last Post: 16-02-2016, 06:54 PM -
Help please - Leadshine EM806 over-current error
By Noplace in forum Motor Drivers & ControllersReplies: 3Last Post: 25-08-2015, 04:02 PM -
Tuning Leadshine EM806 with SY60STH86-3008B
By Noplace in forum Motor Drivers & ControllersReplies: 6Last Post: 17-02-2015, 08:18 PM
