    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 2 Days Ago Has a total post count of 1,651. Received thanks 115 times, giving thanks to others 71 times.
    The motor has the small pulley, the ballscrew the larger pulley.
    That would be 2:1 with 2 turns in gives 1 turn out
    As written it sort of looks like a gearing up but that is the convention for gearing down to get less speed but more torque.
    Chaz's Avatar
    Yep, counted the pulleys, 18 tooth on one, 36 on the other. So making the larger one bigger will give me more torque. Just need to look at space and belt options (assuming there is no problem elsewhere and the drive is working as well as possible).
    Chaz's Avatar
    So I can go to a 72 tooth pulley but no standard belt size works if I want to keep the Centres similar distance. Going to a 60 tooth pulley will give me more torque and with a 400mm belt versus 330mm, is virtually the exact same distance between centres.
    If your spinning the motor faster to try and get more torque, you may actually end up with even less torque.
    Those huge motors usually have very little torque over 500-600rpm.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Chaz's Avatar
    Thanks Ger. This is what has been recommended to me too. With the Acorn tuning where there are 2 parameters, it will thread OK.
    My 2nd lathe has an issue with the encoder which I hope to fix today, will then test back to back and see.
  1. How to properly run in spindle bearings.
    By driftspin in forum Generic Chinese Spindles
    Last Post: 22-11-2018, 04:11 PM
  2. Pokeys57U / Leadshine EM806 / Mach 3 - Confusion
    By Chaz in forum Artsoft Mach (3 & 4)
    Last Post: 29-09-2017, 04:03 PM
  3. How properly to install the rack
    By masinecc in forum Rack & Pinion Systems
    Last Post: 16-02-2016, 06:54 PM
  4. Help please - Leadshine EM806 over-current error
    By Noplace in forum Motor Drivers & Controllers
    Last Post: 25-08-2015, 04:02 PM
  5. Tuning Leadshine EM806 with SY60STH86-3008B
    Last Post: 17-02-2015, 08:18 PM
