    I am redesigning my control box as after learning a bit more discovered a few issues I was previously unaware.
    I have the standard £5 5 axis breakout board and using the UC400eth as well, my question is I power the BoB via USB 5v input, can I then connect the UC400eth to the PC5v and PC GND connectors on the BoB to power it also as at the moment I have a dedicated 5v PSU.
    I currently have 48v PSU for the stepper drivers, 24v PSU for the pump, fans and spindle controls on the BoB, 5v PSU for the UC400eth
    I am aiming to separate the VFD as was originally in the control box and also the pump.
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    The UC400ETh requires a 12V-24V supply, not a 5V supply.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  3. The Following User Says Thank You to Ger21 For This Useful Post:
    You just pointed something out I misread, the uc400 has a step down on board so a 12v24v can be used but it only requires 5v. I misread this when I first got this and been using a dedicated 5v psu for it with no issues, I now no longer require the 5v psu in my set up. Thank you for pointing this out I just made some more space in my box.
  1. The Dreaded X axis stepper error using UC400ETH and UCCNC !!!
    By dachopper in forum CNCdrive (UC100, UC300ETH)
    Last Post: 29-01-2021, 03:27 PM
  2. anyone using an e-cut 1 mhz usb breakout board
    By nobby in forum Control Hardware & Systems
    Last Post: 22-10-2018, 11:50 PM
  3. which breakout board?
    By johngoodrich in forum General Electronics
    Last Post: 12-03-2017, 01:54 AM
  4. Replies: 0
    Last Post: 03-01-2015, 03:40 PM
  5. WANTED: Basic 3 Axis CNC breakout board.
    By Philly in forum Items Wanted
    Last Post: 29-09-2012, 10:39 PM
