Well it is very different, I only have limited experience of CNC systems. I built a small one that used an Ardiuno with the CNC shield.
I then bought the Workbee as I wanted a bigger machine that was quicker than the plywood one!
I use Fusion 360 to do the design work in and to produce the G code. I am pleased with the new machine and for cutting wood which is my main requirement it works really well. I have just cut some aluminum which has proved to be more of a challenge!
Sent from my BBB100-2 using Tapatalk
19-06-2019 #2
im going to be using it to cut carbon fibre so I hope it is up to the job, can you use a tool probe with the duet? as thats how i set the material level with planet cnc
Planet cnc software - layers
By ravihotwok in forum General DiscussionReplies: 22Last Post: 15-06-2018, 01:54 PM -
Planet CNC controller and software
By sairfan1 in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 24-05-2018, 09:17 AM -
Planet CNC initial setup and limits?
By ravihotwok in forum General DiscussionReplies: 19Last Post: 22-06-2017, 08:09 AM -
Get machine status from wifi CNC machinery
By Crazycreative in forum Programmers CornerReplies: 4Last Post: 31-07-2015, 09:00 AM
